7302 Discussions
BUG: mkl_serv_print() calls kernel32!SetDllDirectoryA for no good reason
michaelkonecny
When pardiso is run with msglvl = 1, for some reason it calls SetDllDirectoryA() from kernel32 and this changes the way DLLs are loaded for the rest of the process execution.
This caused a failing unit test in our company, which took me no less than two and a half weeks time to find the cause of.
I created a public repo here: https://bitbucket.org/konecnymichael/pardiso-setdlldirectory-bug which can be used to reproduce this strange behaviour.
This can be done by simply setting a breakpoint to kernel32!SetDllDirectoryA and running the program in the pardiso-setdlldirectory-bug project.
In a different project, I was able to find out SetDllDirectory was being called from MKL's mkl_serv_print() function.
This happens on both oneAPI toolkit versions 2021.3.0 and 2021.4.0 (currently latest).
This behaviour is very annoying because:
  • it is unexpected
  • it started happening after an update from Intel 19.0
  • it broke delay loading of a library which was called later in a program, which took me two weeks to debug
  • it seems unnecessary
I consider this to be a bug as this call doesn't seem to have been present in the previous versions of MKL and doesn't seem necessary.
I would appreciate if Intel could do either of:
  • remove the SetDllDirectory call
  • at least reset the DLL loading mode to previous settings as not to mess up the behaviour of the process which calls it
Can someone from Intel please have a look at this and get back to me?
It would be great if other people didn't have to go through the two-week debugging frenzy that I did.
P.S.: Your editor in this forum is broken. I don't seem to be able to add more than one image. Please refer to the git repo's readme for a complete description of the problem including pictures.
Ruqiu_C_Intel
Thank you for reaching us. This issue will be available in oneMKL 2022.2. Let's closing this thread now. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
ShanmukhS_Intel
We are able to reproduce this issue at our end. We are working on this issue internally. We will get back to you soon.
Shanmukh.SS
Ruqiu_C_Intel
