Basic problems linking libmkl_lapack95
Boris_B_
I'm trying to learn how to use the MKL version of the LAPACK library under Fortran 90. For this purpose I would like to run the Intel-provided example file gesv.f90 which can be found, for my version of ifort, in/opt/intel/Compiler/11.0/054/Frameworks/mkl/examples/lapack95/source.
So I copied this gesv.f90 into my own user directory, and thenI generated the required modules by doing "make lib32" and "make libem64t" in/opt/intel/Compiler/11.0/054/Frameworks/mkl/interfaces/lapack95 - this created mkl95_lapack.mod and other modules in/opt/intel/Compiler/11.0/054/Frameworks/mkl/lib/32 and/opt/intel/Compiler/11.0/054/Frameworks/mkl/lib/em64t, respectively. After this I do not know what to do. My best attempt was
ifort -I/opt/intel/Compiler/11.0/054/Frameworks/mkl/lib/32gesv.f90 -lmkl_lapack95
which failed with
Undefined symbols:
"_sgesv_", referenced from:
_sgesv_mkl95_ in libmkl_lapack95.a(sgesv.o)
_sgesv1_mkl95_ in libmkl_lapack95.a(sgesv1.o)
"_xerbla_", referenced from:
ld: symbol(s) not found
I tried to add other libraries (-lmkl_core -lmk_lintel, etc.) without success. Help please...
Ron_Green
Boris,
I have moved this thread over to the MKL User Forum where you will find help.
ron
TimP
which failed with
Undefined symbols:
The makefile in the mkl examples directory supports building and running all the examples by "make libem64t" or single examples e.g. by "make gesv.res" so you don't have to read more about mkl linking to get a (more than basic) example. I don't have your old version installed, so, if there is a problem, consider updating. For the 64-bit build, something like
ifort -openmp -I gesv.f90 -lmkl_lapack95_lp64 -lmkl_intel_lp64 -lmkl_core -lmkl_intel_thread
should work for dynamic link. Admittedly, it's confusing when you leave out 1 or more of the required libraries. You need the lapack95 modules and library, plus all the libraries which would be required for the corresponding f77 interface usage.
gcreager
I'm having a similar problem with someone else's app. I need to call ssyev, but I've consistently gotten the undefined symbols reference. We're planning to use MPI, not OpenMP, so I'm assuming the threads element isn't needed, but I'm now concerned that the original coder (who's fairly well lost in this episode) might have simply called the LAPACK routine but not made programmatic calls to include the modules.
So, I've made some structural changes to the configuration script (not using autotools; that's not their way), and here's the failure result I'm getting:
ifort -w -convert big_endian  -mp -I/home/Jidong.Gao/arps5.3.5_20140314/include -I/opt/intel/composer_xe_2013_sp1.0.080/mkl/include -module /opt/intel/composer_xe_2013_sp1.0.080/mkl/include/intel64/lp64 -I/home/Jidong.Gao/tools_thor/netcdflib/include -I/home/Jidong.Gao/tools/HDF4.2r4/include -module /home/Jidong.Gao/arps5.3.5_20140314/modules -O3      -c /home/Jidong.Gao/arps5.3.5_20140314/src/arpsenkf/enkfio3d4wrf.f90
ifort    -O3  -o /home/Jidong.Gao/arps5.3.5_20140314/bin/arpsenkfic arpsenkfic.o initenkfic.o    lib_RecursiveFilter.o module_arps_dtaread.o enkfio3d4wrf.o             \
                               /home/Jidong.Gao/arps5.3.5_20140314/lib/libarps.a       \
                               /home/Jidong.Gao/arps5.3.5_20140314/lib/libenkf.a       \
                               /home/Jidong.Gao/arps5.3.5_20140314/lib/libadas.a -L/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64 -lmkl_lapack95_lp64 -lmkl_intel_lp64 -lmkl_core -L/home/Jidong.Gao/tools_thor/netcdflib/lib -lnetcdf -L/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64 -lmkl_lapack95_lp64 -lmkl_intel_lp64 -lmkl_core -L/home/Jidong.Gao/tools_thor/hdf4lib/lib -lmfhdf -ldf -lz -ljpeg
[1]    Exit 1                        ./makearps -io hdfnet arpsenkfic >& compile.log
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkslv_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scscsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zgetrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dbsrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_serv_xerbla'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cunmqr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ddiamm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlacpy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_ch_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_domain_set_num_threads'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_serv_check_ptr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scsrmultd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dpptrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dpttrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cgetrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_spttrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_get_dynamic'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_s_1i_c_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_ch_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_clahpf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dcopy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_ch_blkldl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scsrmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sskysv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_psol_bwscat_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_psol_fwgath_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_dspffrt2_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zdiatrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_dcsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkslv_unsym_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dgemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_sspffrt2_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_diag_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_sbsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_chgeqz_applycr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcoosm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sbsrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkldl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blklu_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_psol_bwscat_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blkslv1_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cgttrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blkslv_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_stptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_ch_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_psol_fwgath_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slansy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blkslv_unsym_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcsrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cdiamm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ctrmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vsl_serv_threader_get_num_threads_limit'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dsytrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slasr3'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zdiamm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_sswap'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcoomv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_chptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_dpotrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlahpf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_ch_blkldlslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ddiasm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_dbsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_psol_fwgath_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dspffrt2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scoomm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_claspf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_chemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dgeqrf_pfnr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccoogemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_ccsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkldl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blklu_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlaswp'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_ch_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_d_1i_2o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcoomm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blklu_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_zgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkldlslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcoogemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ztrmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_cherk'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_ch_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkslv_unsym_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scscsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dtrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkslv_unsym_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkldlslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkslv1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_dgetrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ssyrk'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dgbtrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cbsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcscmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blkslv_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dsyr2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_ctbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sspffrt2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_dgeqrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_cgs_a'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcsrmultcsr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_icamax'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dzgemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ddiagemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_d_1i_z_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_cgs_i'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zsymm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zbsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_strmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_default_xerbla'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_zher'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_sdot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scsrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkldlslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_scoogemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_spptrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_ch_blkldlslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_ctptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_c_1i_s_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cdiatrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cspffrt2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blklu_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blkslv_unsym_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_zdscal'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blkslv_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sormqr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_d_6i_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_sswap'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_zrot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scoogemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_ch_blkldlslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_zgetrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slabrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_chptrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dormqr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blklu_unsym_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vsl_serv_threader_ordered'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blkslv_unsym_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_zspffrtx_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcoomm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cpptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_clansy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blklu_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_claeh2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_cgetrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zskymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_sgetrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_cgeqrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_zbsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blklu_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blklu_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cgbtrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sskysm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blklu_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlange'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cbsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_sgemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sdiamm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlabrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_d_2i_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_psol_bwscat_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_get_dynamic_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blkslv1_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcscsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_z_1i_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cdiagemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dskymm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_ztptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcsrmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_sgetrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dgbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zhetrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dtrmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slaspf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_dsyr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_ccoosymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_csyrk'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_ch_blkldlslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cpbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_set_progress_interface'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zcopy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dtbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zdiagemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_strmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_sgeqrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_clahef'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cgeqrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcscmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_s_1i_2o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zhgeqz'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_ccoogemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blkslv_unsym_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_ddttrsb'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blkslv_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zgttrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cunmql'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_cgs_i'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ctrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_sbsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scoosv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_cgs_a'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_cgetrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_zlaswp'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcsradd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_c_2i_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zunmrq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sdiasm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blkslv1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dskymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_clasyf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_csptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_ssytrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_dft_bless_node_omp'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_sger'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dsymm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_amuxy_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_df_serv_threader_get_num_threads_limit'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcoosymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slatrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_srot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zunmqr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_spotrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cunmrq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sdiagemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_z_1i_d_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_set_num_threads'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ssyr2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zspffrt2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_s_cs_2i_s_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_domain_get_max_threads'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cdttrsb'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcscsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_cpotrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_ch_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_set_num_threads_local'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccoomv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccsrmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_s_2i_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dbsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slaset'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_cgemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcscsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blkslv1_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_cbsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_ssyr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zgeqrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_psol_bwscat_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zbsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dsyr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dbsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_pds_lp64_get_proc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_drot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_zcoogemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlaed0'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_sgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcsrmultcsr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blklu_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zpotrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_cswap'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_daxpy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_cgeru'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dormlq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sbsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zhptrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_ssytrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_amuxy_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_set_xerbla'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkldlslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zdiasv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkldlslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_zcsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_pre_cgs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scscmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_zswap'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zunglq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_ccsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkslv1_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cdiasm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blklu_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sgeqrf_pf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_ch_blkldlslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zgemm3m'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_cgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_dswap'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_zgetrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vsl_serv_threader_sections'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_d_cd_2i_d_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_ch_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sorglq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cskysm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_diag_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkslv_unsym_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_zspffrt2_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_pardiso_max_threads'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_pre_cgs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_cswap'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_cbsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_s_1i_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_clabrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkslv_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_dpotrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sbsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_clanhe'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sormrq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sdiasv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zskysm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_diag_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcscsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_ch_blkldl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scoosm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zdrot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_ch_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dormrq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccoosm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccsrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_get_max_threads'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zhemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlanhe'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccscsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sormql'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dsyr2k'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_isamax'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_ch_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_ch_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlasyf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_pre_cgs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sorgrq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dormql'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_invs_perm_mod_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blklu_unsym_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dgeqrf_pf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkldlslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkldlslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cbsrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blkslv_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zsyr2k'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_saxpy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cbsrmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blklu_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sgeqrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_psol_fwgath_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ctrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_spotrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zspffrtx'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_d_1i_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_dcsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_ccsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_pre_cgs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_default_progress'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dswap'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_cgemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sorgql'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zbsrmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dgttrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zgeqrf_pfnr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_claswp'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_trs_djacobi'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blklu_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blklu_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_set_pardiso_pivot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlaspf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ccopy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_ladj_mod_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cunmlq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sgbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_df_serv_threader_for_ordered'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_amuxy_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_cpotf2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_ch_blkldl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blklu_unsym_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_ch_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scoosymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcsrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcoosm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_psol_fwgath_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blklu_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_serv_pardiso_pivot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlasr3'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zgemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_dger'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkslv1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zdiasm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlaspf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_claev2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zgghrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_metis_mlevelnesteddissection_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dorgrq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zpptrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkldlslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sspffrtx'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_caxpy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_sgemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_cgs_b'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dpotrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_cher'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zbsrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cdiasv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_dgetrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_cgs_i'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_cgs_a'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_diag_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_ch_blkldlslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ddiasymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_metis_mlevelnesteddissection_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_psol_fwgath_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blkslv_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcsrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_dcsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blkslv_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cgeqrf_pfnr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dskysm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_amuxy_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_pds_lp64_pardiso_max_threads'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sgetrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_spptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blklu_unsym_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_diag_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_ch_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccscsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_scsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vsl_serv_threader_for_ordered'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkslv1_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_serv_get_ncpus'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_df_serv_threader_sections'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkslv1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkldl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlabrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_zsyr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkslv_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_zlaev2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_clange'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cbsrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zgbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlansy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_ch_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_csytrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zbsrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkslv_unsym_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dsymm_nb'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_ch_blkldlslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_df_serv_threader_for'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_spbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_zgeru'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scsrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_ch_blkldlslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dbsrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dgetrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blkslv_unsym_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_default_pardiso_pivot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_ladj_mod_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_psol_bwscat_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zsptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scsrmultcsr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlansy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_sptrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cpptrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_dcoosymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_psol_bwscat_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_dspffrtx_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_zbsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sskymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkldlslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dorglq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_ch_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cgbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blklu_unsym_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_scootrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlaswp'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cungql'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_claset'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cungrq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zdiasymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cgeqrf_pf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sdiasymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dpptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blklu_unsym_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scootrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dpbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sgeqrf_pfnr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zhetrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blklu_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ddiamv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccsradd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkldl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dsptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zsyrk'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zbsrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_ch_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlaed0'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cgghrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_amuxy_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dskysv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_dcootrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_cgs_b'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_clatrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_trs_sjacobix'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blkslv1_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dtrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_dgemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zhptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_psol_bwscat_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcoosv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_cgs_i'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_cbsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_cgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccsrmultcsr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcsradd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_trs_sjacobi'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zpptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_sgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_ch_blkldl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlasyf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcsrmultd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_zpotrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_ch_blkldlslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_chetrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_spotrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkslv_unsym_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcsrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cskymm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blklu_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scsradd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sbsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sbsrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_diag_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkldl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_psol_bwscat_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkslv1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccscmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_ch_blkldl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ddot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dorgql'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blklu_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slange'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_zcsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_c_cc_2i_c_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_zcootrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dbsrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ssyr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cdiamv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blkslv1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cunglq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_cgs_a'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sskymm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zungqr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_ccootrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_scgemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_sspffrtx_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blklu_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_csyr2k'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sdttrsb'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sorgqr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scscmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_serv_get_ncorespercpu'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cpotrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zswap'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcoomv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blklu_unsym_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_ztrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zpbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sdiatrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_amuxy_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_strsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_hao_dag_zgeqrf_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_cgemm3m'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ddiasv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cskysv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_ch_blkldlslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_amuxy_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkslv_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_scsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcoosymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_zgemm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccoosv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccsrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkldl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkslv_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_zcsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_ch_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_set_progress'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_ch_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slacpy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vsl_serv_threader_for'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zherk'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blklu_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zskysv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blklu_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_set_xerbla_interface'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dgeqrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlaset'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_cdotc'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_diag_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlaeh2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_stbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_csymm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlaset'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcsrmultd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_dbsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_clacgv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlahef'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dtptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_c_1i_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_get_dynamic_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_dbsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_scopy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_dgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zhgeqz_applycr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcootrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_dlaswp'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slasyf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slaed0'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_dcsrsymv_af'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blklu_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dsptrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cskymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zgghrd_applycr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blkslv_unsym_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_crot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_blkldl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zrot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_cspffrt2_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccscmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lnnt_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_get_proc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_chetrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dsyrk'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_psol_fwgath_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ssyr2k'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcootrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_zbsrgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_csyr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sgbtrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sdiamv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlacpy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_amuxy_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slaeh2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_csrot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_cgs_b'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blklu_unsym_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcsrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zskymm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_invs_perm_mod_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_csscal'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_ch_blkldlslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_ch_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_ch_blkldl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ssymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkldlslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkslv_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_ao_inquiry'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkslv1_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blkslv_unsym_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcscmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blkl_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cungqr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlaeh2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcoosv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_trs_djacobix'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_clacpy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cgghrd_applycr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlatrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zcoogemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dspffrtx'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_lnnt_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sbsrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zher2k'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_scsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_diag_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkslv_unsym_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_dtrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccootrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_ssptrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_slaswp'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_ch_blkldl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ddiatrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_cgs_b'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkldl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_claed0'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_crot'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_zcoosymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_psol_fwgath_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_cspffrtx_offload'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zdttrsb'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccoosymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccsrsymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_dcoogemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_c_blkslv_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blklu_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dptrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blkslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sormlq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zdiamv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_zbsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_ch_blkldlslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_sgttrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlange'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blkslvs_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_dgemv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cpttrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zsytrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ztrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_ch_blkslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkslv_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkldlslvs_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zunmql'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_idamax'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blklu_ooc_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_sp_ch_blkldl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zungrq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_slaswp'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_c_blkslv1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cbsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_serv_progress'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_ztbtrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcsrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cdiasymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_zaxpy'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zunmlq'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_claswp'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_ssymm_nb'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dorgqr'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcsrmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_c_blkslv_unsym_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_cspffrtx'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dcscmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_z_cz_2i_z_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scoomv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_izamax'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_sp_blkslv_unsym_ooc_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zgbtrf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_scoosymv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dsytrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dbsrmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_chgeqz'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_scsrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_strsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blkslv1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_c_blklu_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_s_6i_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zungql'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_vml_serv_threader_z_2i_1o'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cspblas_sbsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_df_serv_threader_ordered'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dlatrd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zpttrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccoomm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccsrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_ccsrmultd'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ssymm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_dbsrtrsv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zgeqrf_pf'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_blkldlslvs1_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_zpotf2'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_sbsrmv'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_ztrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_blas_lp64_ctrsm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_blas_cher2k'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_serv_set_dynamic'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_ch_blkl_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_ssptrs'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_intel_lp64.so: undefined reference to `mkl_spblas_lp64_mkl_cbsrmm'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkslv1_unsym_omp_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_pds_lp64_blkslv_pardiso'
/opt/intel/composer_xe_2013_sp1.0.080/mkl/lib/intel64/libmkl_core.so: undefined reference to `mkl_lapack_lp64_zlacgv'
make[1]: *** [/home/Jidong.Gao/arps5.3.5_20140314/bin/arpsenkfic] Error 1
make[1]: Leaving directory `/home/Jidong.Gao/arps5.3.5_20140314/src/arpsens'
make: *** [arpsenkfic] Error 2
Suggestions, please! I'm getting a bit desperate.
Thanks, Gerry
Zhang_Z_Intel
gcreager wrote:
I'm having a similar problem with someone else's app. I need to call ssyev, but I've consistently gotten the undefined symbols reference. We're planning to use MPI, not OpenMP, so I'm assuming the threads element isn't needed, but I'm now concerned that the original coder (who's fairly well lost in this episode) might have simply called the LAPACK routine but not made programmatic calls to include the modules.
You either need to link mkl_sequential (if you do not need threads) or mkl_intel_threads (if you need threads). You don't have either of them on your link line. This is likely the problem. For better suggestions on linking, use this tool: https://software.intel.com/en-us/articles/intel-mkl-link-line-advisor
