Blas Performance
Cem_Savas_B_
Hi there,
I am running cblas routines on an older Ubuntu 12.04 (64bit) machine, Intel Core 2 Duo ([email protected] GHz) using the latest 11.0 MKL.
For data of size > 10MB, the performance of
saxpy is 0.9 Gflops, e.g. n = 16777216, t = 0.039717s, where the opcount = 2 * n.
sdot is 1.4 Gflops,e.g. n = 16777216, t = 0.024379s where the opcount = 2 * n - 1.
sgemv is 2.5 Gflops, e.g. m,n = 4096, t = 0.021503s where the opcount =  (2 * n - 1) * m.
However in case of
sgemm the performance exceeds 35 Gflops, e.g. m,n,k = 4096, t = 4.114639s where the opcount = (2*k-1)*m*n.
Yet this should be impossible as the peak performance of the E6600 is 19.2 Gflops for single precision.
lda,ldb,ldc = 4096, alpha=1,beta=0 and
cblas_sgemm(CblasColMajor, CblasNoTrans, CblasNoTrans, 4096, 4096, 4096, 1.0, A, 4096, B, 4096, 0.0, C, 4096);
I have verirfied the results for smaller sizes.
Could someone please tell me how this is possible ?
Thanks a lot,
Cem
Sridevi_A_Intel
Cem,
Can you please provide me a testcase with which you've verified your results? I'll test it and let you know my results and comments
Thank you,
Sridevi
Sridevi_A_Intel
Cem,
I notice that you are running your testcase on dual core machine.MKL uses both cores by default.can you please set “export MKL_NUM_THREADS=1” to measure the performance on a single core?
-Sridevi
