Brief question on ILU and OpenMP
Riccardo_Rossi
Hello everyone,
i am writing here to ask about the MKL implementation of the ILU0 and ILU(k) preconditioners:
are they OpenMP parallel? if so ... only the factorization is parallel or also the "triangular" solves?
what kind of techniques is used inside? is it a multi-level ilu ...
i am asking as the parallelization of the iterative solvers is not difficult, but the parallelization of the solve phase of the ILU is highly non-trivial
thank you in advance
Riccardo
Gennady_F_Intel
Riccardo, both of these preconditioners are not threaded at this moment..
--Gennady
Riccardo_Rossi
A shame ...
is there any plan to have it parallel in future releases of MKL?
in any case thank you for the quick reply
Gennady_F_Intel
yes, we are working on this issue, but I cannot say in when this feature will available.
--Gennady
red_cat
At what stage is the development of this functions?Will the added functions for complex matrices?
red_cat
I am interested in - the developers read this forum?
styc
You can use PARDISO instead. Threaded, much stronger than ILU, has built-in CGS.
Riccardo_Rossi
this is just to say that pardiso works very nicely and is very fast ... but it is a DIRECT SOLVER!!
ILU is for solving really large systems, which can not be solved directly.
I do understand that it is extremely difficult to write an efficient ILU preconditioner, that's exactly the reason for which i orginally started this thread
Riccardo
Gennady_F_Intel
Hello Riccardo,
1) regarding the original question -we do nothave plans at this time to add this feature to the next release of Intel MKL.
2) qoute: "ILU is for solving really large systems, which can not be solved directly". Riccardo, how about out-of-core version of PARDISO? usage of this mode allow to solve the real big task.
--Gennady
red_cat
I want to use iterative methods (Bi-CG Stab, TFQMR and other) for solving dense linear system. I'm doing at the beginning prefiltration dense matrix to obtain a sparse preconditioner, and then use ILU0 or ILUT algorithm for decomposition.
Schaefer__Florian
Since the last post on this topic has been a couple of years ago, I'd like to ask, what is the current state of parallelism for ilu0 preconditioners? Is such a feature on the horizon (or implemented already?).
