Bug dgeqrf mkl_sequential
pat97269
There is a problem with the dgeqrf function in sequential with the last mkl. The intel_thread give me the same results as lapack 3.4.1,, but in the sequential version the matrix seems
unchanged.
I provide a small program and data file for you to confirm that.
I use : ifort testdgeqrf.f90 -lmkl_sequential -lmkl_core -lmkl_intel_lp64
Gennady_F_Intel
the test requires DDG.txt file. e.g: open(10,file='DDG.txt') I see - ddg.log is attached. Is this those file?
pat97269
Yes sorry, in fact i had trouble uploading a *.txt file, so i renamed it .log . It contains the matrix that fails for me ! Thanks
