Bug in ZGEMM for complex infinity inputs
darshan
I am using MKL 10.1.2.024 under Linux on a x86_64 machine.
There appears to be a bug in the MKL implementation of ZGEMM that computes complex(inf, 0) * complex(x, y) to be complex(nan, nan) instead of complex(inf, inf).
The behavior is demonstrated in the attached example program: zgemm_bug_small.cc
which I compiled with: icpc zgemm_bug_small.cc -o zgemm_bug.exe -L$(MKL) -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -lmkl_intel_thread -lmkl_core -lguide -lpthread
Notice I used only the static versions of the libraries and hence had to repeat them in order to resolve link-time conflicts.
Running the example outputs:
[user@machine mkl_test]$ ./zgemm_bug.exe
A = {( 1, 1) ( 0, 0) ( 0, 0)}
B = {( inf, 0) ( 1, 1)
( 0, 0) ( 0, 0)
( 0, 0) ( 0, 0)}
A.B computed using ZGEMM:
C = {( nan, nan) ( 0, 2)}
A.B computed using ZDOTU:
C = {( inf, inf) ( 0, 2)}
Notice that the ZDOTU result is what I would expect and contrary to what ZGEMM returns.
Gennady_F_Intel
Well, the same output we have win32 with version 10.2.
C = {(-1.#IND, -1.#IND) ( 0, 2)}
C = {(1.#INF, 1.#INF) ( 0, 2)}
We will check the problem and let you know if any news.
Thanks for the report.
--Gennady
darshan
Thank you, much appreciated.
Ying_S_Intel
Quoting - darshan
( 0, 0) ( 0, 0)
( 0, 0) ( 0, 0)}
Dear Customer,
Thanks for your report, this issue has been submitted to our internal development tracking database for futher investigation, we will inform you once a new update becomes available.
Here is a bug tracking number for your reference: 200083929.
Ying
