7302 Discussions
Bug report: floating divide by zero error in dgeev and possibly also others
yelh2015
Hi friends,
am using the OneAPI 2025.0 and 2015.1 HPC bundles to compile the following Fortran code:
solv.f:
      program main
      implicit none
      integer(kind=4) :: info,lwork,i
      real(kind=8), dimension(12) :: work
      real(kind=8), dimension(3) :: er,ei
      real(kind=8), dimension(3,3) :: mat,vl,vvr
      lwork=12
      mat=0.d0
      do i=1,3
        mat(i,i)=1.d0
      enddo
      call dgeev('N','V',3,mat,3,er,ei,vl,3,vvr,3,work,12,info)
      end program main
My Makefile is:
solv:
       ifx -O0 -g -fpe0 -gdwarf-2 -c solv.f
       ifx -O0 -g -fpe0 -gdwarf-2 -o solv solv.o -lmkl_lapack95_lp64 -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread
clean:
        rm -f solv solv.o
Running the program produces 'floating divide by zero' error. The program runs well if compiled by OneAPI 2024.2, or gfortran, or other Intel compiler versions dated 2020,2018, etc. Also, the error does not show up if the code is compiled by other options like "-O2".
Similar error is also found for zhegvx (I do not have a testing program to reproduce it). The dependencies on the versions of the Intel compilers & MKL libraries, as well as the compiler options, are all the same as dgeev.
I am using Xubuntu 22.04 operating system.
I would be grateful if you can look into it. Thank you very much.
Dr. Lin-Hui Ye
Peking University.
Ruqiu_C_Intel
Hello Dr. Lin-Hui Ye,
Thank you for posting your issue.
Unfortunately, we didn't reproduce the issue with IFX 2025.1.1
rcao8@pvc01:~/issues/mkl$ ifx -O0 -g -fpe0 -gdwarf-2 -c solv.f
rcao8@pvc01:~/issues/mkl$ ifx -O0 -g -fpe0 -gdwarf-2 -o solv solv.o -lmkl_lapack95_lp64 -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread
rcao8@pvc01:~/issues/mkl$ ./solv
rcao8@pvc01:~/issues/mkl$ ifx -v
ifx version 2025.1.1
Can you try again with ifx 2025.1.1?
Ruqiu
Ruqiu_C_Intel
Thank you again for posting the issue.
We can run out error with oneMKL 2025.0 + ifx 2025.1.1. But it works well with oneMKL 2025.1 + ifx 2025.1.1. Please update to oneMKL 2025.1.
