Build failure due to duplicate definitions
Raghavendra_Udupa
pstran and pdtran are defined in both mkl_pblas.h and mkl_scalapack.h. Causes build to fail with visual studio, unless commented out from mkl_scalapack.h
Gennady_F_Intel
thanks for the issue - we will check
Gennady_F_Intel
yes, there is such problem. We will fix it as soon as possible and let you know when the fix would be available.
Gennady_F_Intel
the issue is escalated. here is the issue number for reference - DPD200522866.
