7298 Discussions
C++ MKL BLAS wrappers vs expression templates
Anwar_Ludin
This is a conceptual question:
Expression templates are a popular technique in C++ in order to implement Matrix and Array operations by avoiding unnecessary temporaries and loop unrolling. In other words using expression templates, an expression such as D = A+B+C, where D, A, B & C are matrices will not incur the temporaries usually resulting in a naive C++ implementation. How does this compare in performance terms by using C++ wrappers around the MKL BLAS routines. In other words will a naive implementation of a Matrix/Array class wrapping the optimized BLAS routines perform at least as well as an implementation using expression templates?
realise this question is quite general in essence, but would be quite grateful if someone could provide me some hints on this.
Thanks!
Zhang_Z_Intel
Have you looked at Eigen? http://eigen.tuxfamily.org/index.php?title=Main_Page
Anwar_Ludin
Yes I am aware of Armadillo, Blitz, Eigen and recently Blaze, which all use expression templates in one form or the other to do loop unrolling and avoid temporaries. Eigen has a very spurious benchmark (in my opinion) where it asserts that it has performance similar to Intel MKL using expression templates (http://eigen.tuxfamily.org/index.php?title=Benchmark). After some digging I realized that their benchmark was using a single thread only.
My original question is: If I write naive OOP wrappers around the MKL routines, will I get performance in par with libraries using expression templates but *not* the MKL routines? Most of the afore-mentioned libraries are very opaque in nature with very little documentation about their internals, which kinda makes it difficult to extend them.
