7298 Discussions
C++ Nonsymmetric Complex Eigenvalue Problems
Maciej_B_Intel
Hello!
I'm trying to compute only one eigenvector, corresponded with max eigenvalue and I'm using sets of method decribed here.
Comparing to cgeev method I'm receiving same eigenvalues but different eigenvectors values. Is it expected? What should I do to get same eigenvector?
Thank you!
Ruqiu_C_Intel
Hi Maciej,
Thanks your question! Noted you have raised a ticket about this question at Intel online service support center. Let's follow-up it through the ticket. And if needed, we will update here to make others in Developer Zone be aware of the solution.
Ruqiu
