7301 Discussions
C++ code for uint128_t divide_uint128_by_uint64(...)
richter__dan
How to program function in C++ in Visual Studio 2022
uint128_t divide_uint128_by_uint64(uint128_t dividend, uint64_t divisor, uint64_t* remainder)
without using big number libraries? Note the result can exceed 64-bit i.e. I can't use _udiv128 intrinsic.
Do you know of a link to the Intel sample code?
richter__dan
What do you think about this code:
struct uint128_t {
    uint64_t hi;
    uint64_t lo;
uint128_t divide_uint128_by_uint64(uint128_t dividend, uint64_t divisor, uint64_t* remainder) {
    if (divisor == 0) {
        throw std::runtime_error("Division by zero");
    uint128_t quotient = { 0, 0 };
    // Perform the division manually for uint128_t
    uint64_t temp_rem = 0;
    for (int i = 127; i >= 0; --i) {
        temp_rem = (temp_rem << 1) | ((dividend.hi >> (i - 64)) & 1);
        if (temp_rem >= divisor) {
            quotient.hi |= (1ULL << (i - 64));
            temp_rem -= divisor;
    for (int i = 63; i >= 0; --i) {
        temp_rem = (temp_rem << 1) | ((dividend.lo >> i) & 1);
            quotient.lo |= (1ULL << i);
    *remainder = temp_rem;
    return quotient;
