C vs Fortran documentation
Weeks__John
Using MKL in C 2020 update 2
In looking for C documentation for the ?ggevx family of eigenvalue routines, I found that my headers didn't match the documentation. I finally figured out that my headers are C headers for the Fortran routines; if I look at the MKL C documentation, I find LAPACKE_?ggevx() with quite different calling signature.
A quick scan of the C documentation didn't give me an overview of this LAPACKE set of functions. Where would I find it? Is this the preferred way to call from C/C++?
Thanks. I feel like I'm going to be embarrassed when I get the answer, but I'm too old to care
mecej4
There are three ways to call MKL Lapack routines from C:
  1.  Call the Fortran callable routine, keeping in mind that your C call should pass arguments in the same way as Fortran does;
  2. The LapackE C interface with work arrays allocated, used and de-allocated inside MKL, and
  3. The LapackE C interface with work array related arguments in the argument list.
For details, see the MKL documentation .
mecej4
Gennady_F_Intel
and you may find out many of such examples into mklroot\examples directory
Weeks__John
Thank you to you both, and apologies for the late reply.
