Calculate determinant for matrix using MKL
nguyen_k_
Hi, I need to calculate the determinant of a square matrix with MKL(ipp 9.0 - parallel_studio_xe_2016). I searched solution for whole day but still not find the solution.
Which approach should I follow?
Thank you.
mecej4
One way is to perform the permuted LU decomposition using ?getrf(). Those routines replace the input matrix A by L and U, with L having a unit diagonal. Therefore, the determinant is simply evaluated as Πi=1..n (aii) after the call to ?getrf() has returned.
Alexander_K_Intel2
Are you interested in determinant of sparse or dense matrix? If dense than mecej4 is correct - dgetrf is the way to find it. For sparse matrix dss routine return determinant value
Alex
nguyen_k_
Thank you all, I'll try ?getrf()
