Call dfsNewTask1D from C#
Chris_S_1
Hey,
I'm trying to get the spline functionality to work in C#. I don't seem to know what to put in place for the DFTaskPtr. I can see it's a void pointer in the mkl_df_types.h file, but I don't know how to translate that to C#.
I naively did the following:
    [SuppressUnmanagedCodeSecurity]
    internal sealed class MklNative
        [DllImport("mkl_rt.dll", CallingConvention = CallingConvention.Cdecl, ExactSpelling = true, SetLastError = false)]
        internal static extern int dfsNewTask1D(ref IntPtr task, int nx, double[] x, int xhint, int ny, double[] y, int yhint);
Which doesn't work. Any help would be welcome.
Gennady_F_Intel
there is no such example ready to show - you may look at this https://software.intel.com/en-us/articles/using-intel-mkl-in-your-c-program KB article and see some C#examples.
Chris_S_1
Those examples don't show what to do about the void pointer DFTaskPtr, which is the problem. I don't need a full example, just need to know the proper field to put in the place when making the extern call.
Andrey_N_Intel
Hi Chris,
I created a simple C# example which constructs linear spline using Data Fitting component of Intel MKL. Please, have a look and let me know, if it helps.
Andrey
