7300 Discussions
Calling FFTW3 by Fortran with MPI, types of variables by using iso_c_binding
dyun
I am working on a complicated fortran code, which uses MPI and calls FFTW3 functions directly.
As FFTW3 manual pdf file says, the integer is replaced by integer(c_intptr_t), the complex becomes complex(c_double_complex). What's the difference between integer type and integer(c_intptr_t) type data (also the difference between complex and complex(c_double_complex) )? Whether I can use integer(c_intptr_t) the same as integer, or vice versa? Moreover, can I pass values to each other?
For example,
integer :: a
integer(c_intptr_t) :: b
a=1
b=a
What's the value and type of b now?
mecej4
In general, pointers and integers are different kinds of integers and should not be mixed. The distinctions may be based on storage size (i.e., 4, 8, etc. bytes), signed/unsigned (from the C point of view) and the restrictions on what can be done with/to pointers versus integers. The C_INTPTR_T of Fortran is the same as the intptr_t type of C.
Here is a small test program that you can run in your environment to establish storage sizes.
program tst
use iso_c_binding
integer :: i4
integer(8) :: i8
integer(c_intptr_t) :: ix
write(*,*)sizeof(i4),sizeof(i8),sizeof(ix)
end program
