Calling Pardiso failed after enabling OpenMP in Visual studio
Wu__Yongli
Pardiso in my Fortran program works well if I do not use OpenMP.
However, after I change the setting in Visual studio for enabling OpenMP, by:
         Project > Configuration Properties > Fortran > Language > Process OpenMP Directives > Generate Parallel Code (/Qopenmp)
The error comes at calling Pardiso, showing:
         forrtl: severe (157): Program Exception - access violation
Does anyone know how to solve this problem?
Thanks a lot!
Yongli
MariaZh
Hi Yongli,
Can you please provide more details about your MKL version and reproducer for the case if possible?
Maria
Wu__Yongli
Hi Maria,
Thank you very much for your reply.
My MKL version: Intel® MKL 2018
Besides, I attached the code for reproducer. The code was downloaded from (http://www.pardiso-project.org) with minor modifications.
If I set  Project > Configuration Properties > Fortran > Language > Process OpenMP Directives > Generate Sequential Code (/Qopenmp_stubs), the program works.
However, the problem (as previously described) comes when the above setting is changed as " ....> Process OpenMP Directives > Generate Parallel Code (/Qopenmp)".
Thanks and best regards,
Yongli
C----------------------------------------------------------------------
C       Example program to show the use of the "PARDISO" routine
C       for symmetric linear systems
C --------------------------------------------------------------------
C      This program can be downloaded from the following site:
C      http://www.pardiso-project.org
C
C  (C) Olaf Schenk, Institute of Computational Science
C      Universita della Svizzera italiana, Lugano, Switzerland.
C      Email: [email protected]
        PROGRAM pardiso_sym
        use omp_lib
        IMPLICIT NONE
C..     Internal solver memory pointer
        INTEGER*8 pt(64)
C..     All other variables
        INTEGER maxfct, mnum, mtype, phase, n, nrhs, error, msglvl
        INTEGER iparm(64)
        INTEGER ia(9)
        INTEGER ja(18)
        REAL*8  dparm(64)
        REAL*8  a(18)
        REAL*8  b(8)
        REAL*8  x(8)
        REAL*8  y(8)
        INTEGER i, j, idum, solver
        REAL*8  waltime1, waltime2, ddum, normb, normr
C.. Fill all arrays containing matrix data.
        DATA n /8/, nrhs /1/, maxfct /1/, mnum /1/
        DATA ia /1,5,8,10,12,15,17,18,19/
        DATA ja
     1        /1,          3,                 6,    7,
     2               2,    3,          5,
     3                     3,                             8,
     4                          4,                  7,
     5                                 5,     6,    7,
     6                                        6,          8,
     7                                              7,
     8                                                    8/
        DATA a
     1     /7.d0,       1.d0,              2.d0, 7.d0,
     2           -4.d0, 8.d0,        2.d0,
     3                  1.d0,                          5.d0,
     4                        7.d0,              9.d0,
     5                               5.d0, 1.d0, 5.d0,
     6                                     0.d0,       5.d0,
     7                                           11.d0,
     8                                                 5.d0/
C  .. set right hand side
      do i = 1, n
        b(i) = 1.d0
      end do
C
C  .. Setup Pardiso control parameters und initialize the solvers
C     internal adress pointers. This is only necessary for the FIRST
C     call of the PARDISO solver.
C
      mtype     = -2  ! unsymmetric matrix symmetric, indefinite
      solver    =  10  ! use sparse direct method
C..   Reordering and Symbolic Factorization, This step also allocates
C     all memory that is necessary for the factorization
      phase     = 11     ! only reordering and symbolic factorization
      msglvl    = 1      ! with statistical information
      iparm(33) = 1      ! compute determinant
      !write(*,*) "proc nums:", omp_get_num_procs()
      call mkl_set_dynamic(0)
      call omp_set_num_threads(2)
      call mkl_set_num_threads(2)
      IPARM(3) = 2
      CALL pardiso (pt, maxfct, mnum, mtype, phase, n, a, ia, ja,
     1              idum, nrhs, iparm, msglvl, ddum, ddum, error, dparm)
      WRITE(*,*) 'Reordering completed ... '
      IF (error .NE. 0) THEN
        WRITE(*,*) 'The following ERROR was detected: ', error
        STOP
      END IF
      WRITE(*,*) 'Number of nonzeros in factors   = ',iparm(18)
      WRITE(*,*) 'Number of factorization MFLOPS  = ',iparm(19)
C.. Factorization.
      phase     = 22  ! only factorization
      IF (iparm(33).EQ.1)  THEN
            write(*,*) 'Log of determinant is  ',  dparm(33)
      ENDIF
      WRITE(*,*) 'Factorization completed ... '
        STOP
      ENDIF
C.. Back substitution and iterative refinement
      iparm(8)  = 1   ! max numbers of iterative refinement steps
      phase     = 33  ! only solve
     1              idum, nrhs, iparm, msglvl, b, x, error, dparm)
      WRITE(*,*) 'Solve completed ...  '
      WRITE(*,*) 'The solution of the system is '
      DO i = 1, n
        WRITE(*,*) ' x(',i,') = ', x(i)
      END DO
       call sleep(3)
      END
MariaZh
Hi Yongli,
First thing that I've noticed: the Intel(R) MKL PARDISO interface is a little bit different, there is no dparm parameter, for instance.
Please refer to the https://software.intel.com/en-us/mkl-developer-reference-fortran-pardiso for the detailed description.
Can you please adjust your code accordingly and double check if the issue is still there?
Maria
Wu__Yongli
Hi Maria,
Thank you very much for your quick reply and suggestions.
Then, I will check it as your suggestion first.
Yongli
Zhukova, Maria (Intel) wrote:
Hi Yongli,
Maria
Wu__Yongli
Hi Maria,
The interface has been adjusted to be the same as the attached code.
However, the problem remains.
Your further suggestions will be highly appreciated.
Yongli
C
        PROGRAM pardiso_sym
        use omp_lib
        IMPLICIT NONE
        INTEGER*8 pt(64)
        INTEGER iparm(64)
        INTEGER ia(9)
        INTEGER ja(18)
        REAL*8  dparm(64)
        REAL*8  a(18)
        REAL*8  b(8)
        REAL*8  x(8)
        REAL*8  y(8)
        INTEGER i, j, perm, solver
        DATA ja
     1        /1,          3,                 6,    7,
     2               2,    3,          5,
     3                     3,                             8,
     4                          4,                  7,
     5                                 5,     6,    7,
     6                                        6,          8,
     7                                              7,
     8                                                    8/
        DATA a
     3                  1.d0,                          5.d0,
     4                        7.d0,              9.d0,
     5                               5.d0, 1.d0, 5.d0,
     6                                     0.d0,       5.d0,
     7                                           11.d0,
     8                                                 5.d0/
      do i = 1, n
        b(i) = 1.d0
      end do
C
C
      IPARM(3) = 2
      call pardiso (pt, maxfct, mnum, mtype, phase, n, a, ia, ja,
     1              perm, nrhs, iparm, msglvl, b, x, error)
        STOP
      END IF
C.. Factorization.
      ENDIF
        STOP
      ENDIF
      DO i = 1, n
      END DO
       call sleep(3)
      END
Hi Yongli,
Maria
Gennady_F_Intel
I checked the problem with the latest 2019 u3 version of mkl from command line, win64, lp64 API linked. the test passed. the log file is attached.
Wu__Yongli
Dear Maria and Gennady,
Much appreciated for your kind replies and suggestions.
Now, the code works even the version is 2018. I just checked and adjusted the previous code according to the examples in the folder of the Intel MKL installation directory: • examples/solverf/source.
Yongli
