Calling of VML Mathematical Functions [in-place operation]
Marcus_W_1
HI,
I have a question concerning the use of Vector Mathematical Functions. The documentation does not contain a hint whether one can apply the same argument twice [in-place operation] without any side effects. For example for two vectors a, b the operation a = a + b should be computed via
vdadd( n, a, b, a ); [in-place operation]
instead of creating a working array y first and copy the result to array a again:
[plain]y = new double;
vdadd( n, a, b, y );
copy(source: y, destination: a);[/plain]
I have tested it and it works for vdadd. My question is is not restricted to vdadd, more general to all other Mathematical functions as for example vdsqr, vzconj, vdpow etc. I can test each function before I will use it but this is rather time consuming and can change from release to release of the MKL Library.
Thanks in advance,
Markus
Chao_Y_Intel
Hi Markus,
It is true that all of the VML can work with the in-plance operation. Check the document here:
http://software.intel.com/sites/products/documentation/doclib/mkl_sa/11/mklman/GUID-CF5F14C8-F9B1-4846-87F5-FB1CC0AD5972.htm
Chao
Marcus_W_1
Hi Chao,
thank you very much, I was blind...
Markus
Royi
I think the updated place to look for it is:
Intel MKL Developer Reference - Vector Mathematical Functions
At least the In Place support holds for Intel MKL 2018 Update 2.
