7303 Discussions
Can I replace xerbla with my own error handler?
rbarron
TimP
Presumably, the MKL xerbla is the same as the one from netlib, and you should be able to substitute your own modification, as you would with the public version.
rbarron
Thank you, that works. The version of XERBLA in "mkl_c.lib" calls other MKL functions, like mkl_set_serial and MKL_SET_PARALLEL, but that code seems to be no more than the wrapper that MKL puts around every BLAS function. I thought there might be more to it.
