7303 Discussions
Can I use MKL routines when running on GPU?
eliopoulos
I want to enable my Intel iris xe graphics GPU to run a Fortran program which includes MKL routines. Is this possible? I have created and attached a simple reproducer. When I build the solution, I get:
Rebuild started at 01:30...
1>------ Rebuild All started: Project: z2 (IFX), Configuration: Release x64 ------
Deleting intermediate files and output files for project 'z2', configuration 'Release|x64'.
Compiling with Intel® Fortran Compiler 2024.0.2 [Intel(R) 64]...
z2.for
ifx: warning #10148: option '/size-llp64' not supported
Linking...
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.0.2 Build 20231213
Copyright (C) 1985-2023 Intel Corporation. All rights reserved.
13292354.o : warning LNK4078: multiple '__CLANG_OFFLOAD_BUNDLE__openmp-s' sections found with different attributes (40500040)
Embedding manifest...
Build log written to "file://C:/Work/Work/2023%20OPENZDM/Fortran%20folder/z2/z2/x64/Release/BuildLog.htm"
z2 - 0 error(s), 3 warning(s)
========== Rebuild All: 1 succeeded, 0 failed, 0 skipped ==========
========== Rebuild completed at 01:30 and took 01.366 seconds ==========
and when I run the program:
Libomptarget error: Unable to generate entries table for device id 0.
Libomptarget error: Failed to init globals on device 0
Libomptarget error: Run with
Libomptarget error: LIBOMPTARGET_DEBUG=1 to display basic debug information.
Libomptarget error: LIBOMPTARGET_DEBUG=2 to display calls to the compute runtime.
Libomptarget error: LIBOMPTARGET_INFO=4 to dump host-target pointer mappings.
Libomptarget error: Source location information not present. Compile with -g or -gline-tables-only.
Libomptarget fatal error 1: failure of target construct while offloading is mandatory.
Is there anything I can do to solve this issue?
Mahan
If you use the following for compilation, does it help?
ifx /Qiopenmp /Qopenmp-targets:spir64 -fsycl mkl_sycl.lib mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib OpenCL.lib
eliopoulos
Can anyone tell me if it works on better Intel GPU?
Mahan
Hi
Could you please set these environment variables and run the application through command line
set OMP_TARGET_OFFLOAD=MANDATORY
set LIBOMPTARGET_PLUGIN=LEVEL_ZERO
set LIBOMPTARGET_DEVICETYPE=GPU
eliopoulos
It does not work. It produces the same errors:
C:\Work\Work\2023 OPENZDM\Fortran folder\z2\z2\x64\Release>set OMP_TARGET_OFFLOAD=MANDATORY
C:\Work\Work\2023 OPENZDM\Fortran folder\z2\z2\x64\Release>set LIBOMPTARGET_PLUGIN=LEVEL_ZERO
C:\Work\Work\2023 OPENZDM\Fortran folder\z2\z2\x64\Release>set LIBOMPTARGET_DEVICETYPE=GPU
C:\Work\Work\2023 OPENZDM\Fortran folder\z2\z2\x64\Release>ifx /Qopenmp-targets:spir64 /Qopenmp /Qiopenmp /Qmkl z2.for
C:\Work\Work\2023 OPENZDM\Fortran folder\z2\z2\x64\Release>z2
Mahan
eliopoulos
Mahan
Thanks for letting me know.
Also remember to set those environment variables.
