Can not use multi threading
orhun
I cannot utilize multi threading for the following functions. cblas_daxpy, cblas_dscal and cblas_dgemv. I have vectors and matrices with n=8000. But it looks like multi threading is not used. I arrived this conclusion by looking at system monitor. I am linking with "-L/opt/intel/mkl/10.0.2.018/lib/32 -lmkl -liomp5 -lpthread -lm".
I am using
mkl 10.0.2.018
Fedora 8 (32 bit)
g++ (GCC) 4.1.2 20070925 (Red Hat 4.1.2-33)
Intel Core2 CPU T5600 @ 1.83GHz (Mac Mini)
mkl_domain_get_max_threads(MKL_BLAS) returns 2
mkl_get_dynamic() returns 1
mkl_get_max_threads() returns 2
mkl_set_dynamic(0) does not seem to force using 2 threads.
Is there anything else I should be doing?
TimP
Level 1 BLAS functions, including ?axpy and ?dscal, generally aren't threaded, because vectorization is usually the only effective parallelization. A run time check for problem size at that level would hurt performance on shorter loops. Even ?gemv would usually get more benefit from threading if it is possible to thread in your code, so as to give each thread an independent instance of the function.
As your inner loops may be long enough to benefit from threading, since both cores share cache, you can thread them yourself with a more recent compiler, which includes OpenMP as well as auto-vectorization, such as g++ 4.3 or icpc.
