7301 Discussions
Can't activate my parallel_studio_xe_2017_update1
chenweilin
I buy parallel_studio_xe_2017_update1 at 2016. And I install it on my server. Due to some reasons, I need to reinstall the operating system on the server that I need to handle. So I need reinstall parallel_studio_xe_2017_update1 with license key. But some errors have occurred。
My network is normal. 企业微信截图_17223210858676.pngHow should I solve this problem,
SofeaAzrin_A_Intel
Thank you for your questions.
From your issue, you mentioned that you're re-installed the OS. You can double check the license file. If you have a license file, ensure that it is correctly placed in the appropriate directory. The default location is often within the installation directory, under a 'licenses' or similar folder.
SofeaAzrin_A_Intel
Hi, may I know if there is any updates?
