7302 Discussions
Cluster Sparse Solver(cpardiso) reordering problem
GwangSeok_S_
Hello.
I tried to solve a large linear equation (1,000,000 x 1,000,000 / bandwidth = 100 or 1000) with cpardiso.
( the matrix type is real and symmetric indefinite. )
I have some problems about reordering time and memory.
CPARDISO's reordering phase is compare to slower than the other phase. So I checked event time using Traceanalyzer.
CPARDISO used only one process(rank 0) for reordering and Rank 0 collected information on the divided A matrix on each process.
As a result, When I solved the bandwidth 1,000 equation, It occurred insufficient memory error. (※bandwidth 100 equation was resolved)
Should CPARDISO do the reordering and collect the A matrix in only rank 0 ?
Does rank 0 must have a lot of memory to solve a large system?
How to solve this problem ?
The version of MKL is mkl 11.3, which was bundled with parallel studio xe 2016 cluster edition.
This is the setting for cpardiso
iparm[ 0] = 1;
iparm[ 1] = 0; (I also tried iparm[1]= 2 and 3)
iparm[ 5] = 0;
iparm[ 7] = 0;
iparm[ 9] = 8;
iparm[10] = 0;
iparm[12] = 0;
iparm[17] = 0;
iparm[18] = 0;
iparm[20] = 1;
iparm[26] = 0;
iparm[27] = 0;
iparm[34] = 1;
iparm[39] = input_value[1];
iparm[40] = input_value[2];
iparm[41] = input_value[3];
I used 4 nodes that are connected InfiniBand and Each node have 32 GB RAM.
Gennady_F_Intel
Said M,  the reodering step is not threaded at this version of MKL. We are working on this improvement at this moment and will keep you informed when this feature will be implemented. thanks,
