Compilation Errors with MKL_DIRECT_CALL_SEQ
Daniele_S_1
I'm compiling a cpp file that includes mkl.h and contains a single cblas_dgemm call with the following:
icpc -DMKL_DIRECT_CALL_SEQ -DMKL_ILP64 -I/opt/intel/mkl/include -c -o main.o main.cpp
Compilation breaks and I get mutliple times the following message:
error: expression must be an lvalue or a function designator
    cblas_dgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans, 4, 4, 4, 1, A, 4, B, 4, 1, C, 4);
If a remove -DMKL_DIRECT_CALL_SEQ the compilation works as expected.
Is this a bug or am I doing anything wrong?
Daniele
Daniele_S_1
I forgot to mention that the very same code used to compile with Intel MKL 11.2 and that now I've upgraded to Intel MKL 11.3.2.
Daniele
Ying_H_Intel
Hi Daniele,
Thanks for the report.  The issue looks familiar. We will check and get back to you later.
Ying
Sarah_K_Intel
Hi Daniele~
Thank you for your interest in this functionality!  Direct call support for CBLAS interfaces was introduced in Intel MKL 11.2.2, which may explain why the compilation works as expected for Intel MKL 11.2.  The implementation assumes that variables, rather than literals, are passed as arguments to the cblas_dgemm call.  We will need to change the implementation to allow both variables and literals to work for the CBLAS interfaces with direct call.
In the meantime, if you change your code to:
      MKL_INT four = 4;
      double one = 1.0;
      cblas_dgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans, four, four, four, one, A, four, B, four, one, C, four);
instead of
does the compilation succeed?
Sarah
Ying_H_Intel
Dear All,
Just update the thread.  MKL 2017 update 1 release recently, which fix the issue.
@Daniele, thank you for report the bug!
Ying
