Compiling in a mingw64/msys2 environment
Martin_S_6
I'm trying to build my C program in a mingw64 (msys2) environment using cmake.
I successfully compiled my example code with inkl mkl_malloc() call, but once including vdMul() function I get the following compile error:
Warning: .drectve `-defaultlib:"uuid.lib" ' unrecognized
Warning: corrupt .drectve at end of def file
C:/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/mkl/lib/intel64/mkl_intel_ilp64_dll.lib(./_tmp/interface_win32e_ilp64_dll/vml_fb_cpuid_iface.obj):(.text[mkl_vml_serv_cpu_detect]+0xcb): undefined reference to `__security_check_cookie'
My libraries are included in my cmake config:
find_library(MKL_CORE_LIBRARY mkl_core_dll PATHS ${MKL_ROOT_DIR}/lib/${MKL_ARCH_DIR} ${MKL_ROOT_DIR}/lib/)
find_library(MKL_INTEL_ILP64_LIBRARY mkl_intel_ilp64_dll PATHS ${MKL_ROOT_DIR}/lib/${MKL_ARCH_DIR} ${MKL_ROOT_DIR}/lib/)
find_library(MKL_SEQUENTIAL_LIBRARY mkl_sequential_dll PATHS ${MKL_ROOT_DIR}/lib/${MKL_ARCH_DIR} ${MKL_ROOT_DIR}/lib/)
Is there a compatibility problem here or am I doing something wrong?
Gennady_F_Intel
Martin, What mkl's version you are using?  The similar symptoms we were met with another performance library -- IPP. Please have a look at this post - https://software.intel.com/en-us/forums/intel-integrated-performance-primitives/topic/393628.
Martin_S_6
Gennady Fedorov (Intel) wrote:
Martin, What mkl's version you are using?  The similar symptoms we were met with another performance library -- IPP. Please have a look at this post - https://software.intel.com/en-us/forums/intel-integrated-performance-pri....
I'm using version 11.3.
I see this post: https://software.intel.com/en-us/articles/intel-integrated-performance-primitives-intel-ipp-for-windows-lnk2001-error-unresolved-external-symbol-_security_cookie
It seems to refer to VC++ compilers and .net versions. Could this still be related to my issue when using gcc?
TimP
Did you check whether including the bufferoverflowu.lib may resolve it?  It's generally difficult to use MKL with mingw/
