Conflict between IMSL and MPI
Hewei_S_
I am trying to divide my fortran code into several parts and I want to parallelize each part by using MPI. For each part, I use IMSL library to solve an optimization problem (use BCONF). However, I find that IMSL library has its own subroutines about MPI and it does not allow me to call the standard MPI start subroutine "Call MPI_INIT(ierror)". It just gives me an fatal error and ends the program.
I give two examples to illustrate the issue.
Example 1, print "Hello World " from each node:
program main
   use mpi
   implicit none
  integer ( kind = 4 ) error
  integer ( kind = 4 ) id
  integer ( kind = 4 ) p
  call MPI_Init ( error )
  call MPI_Comm_size ( MPI_COMM_WORLD, p, error )
  call MPI_Comm_rank ( MPI_COMM_WORLD, id, error )
  write ( *, * ) '  Process ', id, ' says "Hello, world!"'
  call MPI_Finalize ( error )
end program
When I compile and run without IMSL library, it gives me the correct answer:
mpif90 -o a.out hello_mpi.f90
mpiexec -n 4 ./a.out
   Process            3  says "Hello, world!"
   Process            0  says "Hello, world!"
   Process            2  says "Hello, world!"
   Process            1  says "Hello, world!"
Now If I do nothing to the code but just add IMSL library, it will cause the error:
mpif90 -o a.out hello_mpi.f90 $LINK_FNL_STATIC_IMSL $F90FLAGS
 *** FATAL    ERROR 1 from MPI_INIT.   A CALL was executed using the IMSL
 ***          dummy routine.  Parallel performance needs a functioning MPI
 ***          library.
 ***          library.
 ***          library.
 ***          library.
In the first example, changing  "$LINK_FNL_STATIC_IMSL" to "LINK_MPI" will cure the problem, but it does not work in a more realistic example here:
Example 2: use MPI and each node use IMSL library to calculate quadrature nodes
program main
    USE GQRUL_INT
    use mpi
    implicit none
  real ( kind = 8 ) QW(10), QX(10)
    CALL GQRUL (10, QX, QW )
end program
When I compile and run, program stops at "MPI_INIT":
 ***          library.
 ***          library.
 ***          library.
 ***          library.
If I change the linking option to $LINK_MPI, the program crashes at the IMSL library subroutine:
mpif90 -o a.out hello_mpi.f90 $LINK_MPI $F90FLAGS
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
a.out              00000000018D5C75  Unknown               Unknown  Unknown
a.out              00000000018D3A37  Unknown               Unknown  Unknown
a.out              000000000188ADC4  Unknown               Unknown  Unknown
a.out              000000000188ABD6  Unknown               Unknown  Unknown
a.out              000000000184BCB9  Unknown               Unknown  Unknown
a.out              000000000184F410  Unknown               Unknown  Unknown
libpthread.so.0    00007EFC178C67E0  Unknown               Unknown  Unknown
a.out              000000000178E634  Unknown               Unknown  Unknown
a.out              000000000178A423  Unknown               Unknown  Unknown
a.out              0000000000430491  Unknown               Unknown  Unknown
a.out              000000000042AACD  Unknown               Unknown  Unknown
a.out              00000000004233D2  Unknown               Unknown  Unknown
a.out              0000000000422FEA  Unknown               Unknown  Unknown
a.out              0000000000422DD0  Unknown               Unknown  Unknown
a.out              0000000000422C9E  Unknown               Unknown  Unknown
libc.so.6          00007EFC16F7BD1D  Unknown               Unknown  Unknown
a.out              0000000000422B29  Unknown               Unknown  Unknown
libpthread.so.0    00007EFDE2A037E0  Unknown               Unknown  Unknown
libc.so.6          00007EFDE20B8D1D  Unknown               Unknown  Unknown
libpthread.so.0    00007FBF21C277E0  Unknown               Unknown  Unknown
libc.so.6          00007FBF212DCD1D  Unknown               Unknown  Unknown
libpthread.so.0    00007F8084FD67E0  Unknown               Unknown  Unknown
libc.so.6          00007F808468BD1D  Unknown               Unknown  Unknown
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   EXIT CODE: 174
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
I am running this code on a UNIX system on my school's supercomputer and I am using intel compiler and MPICH version 3.0.1. My actual code is very similar to the second example, which uses some IMSL subroutines on each node. Can you please help me to make it work? Thank you!
Hewei_S_
I finally found the solution to this problem. I just need to change the flag to $LINK_MPIS$ instead of $LINK_MPI$ and my second code will run without any problem.
Hewei_S_
