7303 Discussions
Confused About MKL Linking Warnings/Errors w/Visual Studio 2015
Darwen__Terence
Hi, I'm updating my static library from a very old version of MKL (circa ~2010) to MKL version 2019 Update 3.  I'm using Visual Studio 2015.  The only changes I made to my existing codebase was to include the new headers, change a call in my code from MKL_FreeBuffers() to mkl_free_buffers() and link to mkl_intel_c.lib, mkl_sequential.lib and mkl_core.lib as told to do by the Intel Math Kernel Library Link Line Advisor.  However, when building, I get a couple hundred warnings like this:
mkl_core.lib(_avx2_set_codelet_cb.obj) : warning LNK4221: This object file does not define any previously undefined public symbols, so it will not be used by any link operation that consumes this library
But, if I no longer link in mkl_core.lib, I'll get 468 unresolved external symbols errors like this:
error LNK2001: unresolved external symbol _mkl_serv_inspector_loaded
Can anyone explain this?  Clearly it seems mkl_core.lib is needed, so I'm not sure why I'm getting those warnings...
Gennady_F_Intel
did you try to build ia32 or intel64 bits project?
Darwen__Terence
Hi Gennady - Thank you for the reply.  I'm building my project as "Win32" using Visual Studio 2015 (v140).
Darwen__Terence
Anyone?  I'd love to get rid of these warnings if possible (without having to indiscriminately ignore LNK4221).  Example warning:
Gennady_F_Intel
The warnings happen when a static linking mode is used only. Actually, these warnings will not affect runtime behavior. Nevertheless, the issue is escalated and we will try to fix this case in one of the future releases. The only workaround we may suggest is dynamic linking mode.
Gennady_F_Intel
The fix of this problem was added to the MKL v.2020 update 4. This update available for download.
