Correct signature for dgesv
MiB19801
What should be the correct signature for P/Invoking dgesv from VB.NET code ?
Chao_Y_Intel
Hello, I checked the following article: http://software.intel.com/en-us/articles/use-intel-mkl-from-microsoft-office-excel You may needs to the following steps: 1>Build custom DLL by builder tools with "stdcall" calling convention. "The Step1: Build custom DLL by builder tools provided by Intel MKL" may provide some help, and the library needs to include C lapack interface 'LAPACKE_dgesv' 2> the function could be called like the following the VB code: Declare Function LAPACKE_dgesv Lib ”mkl_custom.dll” ( ByVal matrix_order As Integer, ByVal n As Integer , ByVal nrhs As Integer, ByVal a As IntPtr, ByVal lad As Integer, ByVal ipiv As IntPtr, ByVal b As IntPtr, ByVal ldb As Integer) As Integer Thanks, Chao
