Correlation
Jérôme_C_
Hi all,
I have a lot of trouble understanding how the correlation/convolution functions are used.
I have looked at the Information from the Manual but the description - involving finite functions - is far too abstract (and I've been used to abstractness as a physicist).
Can someone help me carry out a simple correlation analysis on two trivial vectors, say
v1 =(1, 2, 3, 4, 5, 6, 7, 8, 9, 10)
v2 = (1.01, 1.99, 3.01, 3.99, 5.01, 5.99, 7.01, 7.99, 9.01, 9.99)
(which should be approximatively 1) just to get me going?
Concretely: what should be my input, what will my output look like (and, ideally, why...)?
Here's what I have :
#define XSHAPE 10
#define YSHAPE 10
#define ZSHAPE (XSHAPE-1)+(YSHAPE-1)+1
int test6()
VSLCorrTaskPtr task; // declare the task
MKL_INT mode, xshape, yshape, zshape; //declare some variables
static double x[XSHAPE], y[YSHAPE], z[ZSHAPE]; //declare the input and output arrays
MKL_INT xstride = 1, ystride = 1, zstride = 1; //declare the "increment"
int status, ok, i;
xshape = XSHAPE; //length of vector
yshape = YSHAPE;
zshape = ZSHAPE;
for (i = 0; i<xshape; i++) // initialize the input vectors.
x = i+1;
for (i = 0; i<yshape; i++)
y = i+1 + 0.01*pow(-1,i);
ok = 1; // a priori success.
printf("EXAMPLE executing a correlation task\n");
mode = VSL_CORR_MODE_AUTO; //set mode
vsldCorrNewTask1D(&task, mode, xshape, yshape, zshape); //create task with, as an argument: reference to task object, mode, vectors lengths.
status = vsldCorrExec1D(task, x, xstride, y, ystride, z, zstride); // initialize status with task, vectors and respective increments. Execute task, fill vector z.
if (status != VSL_STATUS_OK) { // problem with the initialization of the status. // conversion from "status type" to int?
printf("ERROR: bad status: %d\n", status);
ok = 0; // boolean of success
for (i = 0; i < yshape; i++)
std::cout << y << std::endl;
printf("EXAMPLE %s\n", ok ? "PASSED" : "FAILED");
return !ok;}
Thanks in advance!
Jérôme
Zhang_Z_Intel
Please check out this code example in your MKL installation: $MKLROOT/examples/vslc/source/vsldcorr_1d_auto.c
It does exactly what you want to do. You can reuse the code and simply plug in your own X and Y arrays.
Jérôme_C_
Hi Zhang,
I already did. It's not so much that the code doesn't work, but more that I don't understand what it does.
I expect(ed) Pearson's product-moment coefficient (see http://en.wikipedia.org/wiki/Correlation_and_dependence),
i.e. an application (R^n) x (R^n)->R, where R represents the set of real numbers.
So, here are my two questions:
1) Is there a function to compute this Pearson coefficient in the MKL?
2) If not, can you tell me what the Output of vsldcorr_1d_Auto.c is?
Thanks in advance.
Jérôme
Andrey_N_Intel
Hi Jerome, To calculate the Pearson coefficient please use Summary Statistics component of Intel MKL. Its API is described at https://software.intel.com/en-us/node/470764. Summary Statistics Application Notes available at https://software.intel.com/en-us/mkl_11.1_sslnotes provide additional details on APIs/usage models/algorithms. I assume the section https://software.intel.com/en-us/node/497928 contains the info on computation of correlation. You might want to have a quick look at the example vsldcorrelationmatrix.c available at MKLROOT/examples/vslc/source of the MKL installation folder which shows how to calculate the correlation and covariance matrices. Also, please have a look at the training materials describing stat component of MKL at https://software.intel.com/en-us/articles/intel-mkl-vsl-training-material, slides 17-19 have the quick high level introduction into Summary Stats. Please let us know if you need further help. Andrey
