7303 Discussions
Crash for a simple 2D MKL FFT example when matrix size is not too larger
strngtn
Environment:  MKL Version: 2020.2.254
Toolchain: Visual Studio Community 16.7.6,  Host x64,  Target x64
CMakeLists.txt:
add_executable(mkl_test_s main.cpp)
target_link_libraries(mkl_test_s mkl_intel_lp64.lib mkl_sequential.lib mkl_core.lib)
#include <chrono>
#include <iostream>
#include <random>
#include "mkl.h"
#include "mkl_dfti.h"
void init_array_random(int size, double *a) {
std::uniform_real_distribution<double> unif(0, 1);
std::random_device rd;
std::default_random_engine re(rd());
for (int i = 0; i < size; ++i) a[i] = unif(re);
void fft(double *datain, double *dataout, int sz) {
DFTI_DESCRIPTOR_HANDLE handle;
MKL_LONG status;
MKL_LONG sizes[2] = {sz, sz};
status = DftiCreateDescriptor(&handle, DFTI_DOUBLE, DFTI_REAL, 2, sizes);
status = DftiSetValue(handle, DFTI_PLACEMENT, DFTI_NOT_INPLACE);
status = DftiCommitDescriptor(handle);
auto start = std::chrono::high_resolution_clock::now();
status = DftiComputeForward(handle, datain, dataout);
auto dur = std::chrono::high_resolution_clock::now() - start;
std::cout
<< "FFT Done. Elapse time = "
<< std::chrono::duration_cast<std::chrono::microseconds>(dur).count()
<< "us" << std::endl;
status = DftiFreeDescriptor(&handle);
int main(int argc, char *argv[]) {
int size = 299; // Crash when size >= 300
double *in = (double *)mkl_calloc(size * size, sizeof(double), 64);
double *out = (double *)mkl_calloc(size * size, sizeof(double), 64);
init_array_random(size * size, in);
fft(in, out, size);
mkl_free(in);
mkl_free(out);
return 0;
Gennady_F_Intel
building this example as is by the trivial way: icl /Qmkl test.cpp and enabling the verbose mode, I see no problems with my run:
>set MKL_VERBOSE=1
>test_2dfft.exe
MKL_VERBOSE Intel(R) MKL 2020.0 Update 2 Product build 20200624 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled processors, Win 2.60GHz intel_thread
MKL_VERBOSE FFT(drfo299:299:299x299:1:1,pack:ccs,tLim:2,desc:0000020CD5E3C700) 1.53ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:2
FFT Done. Elapse time = 111128us
> building like icl /Qmkl=seqential ( exactly like you did) run well also with the outputs:
test_2dfft.exe
MKL_VERBOSE Intel(R) MKL 2020.0 Update 2 Product build 20200624 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled processors, Win 2.60GHz sequential
MKL_VERBOSE FFT(drfo299:299:299x299:1:1,pack:ccs,tLim:1,desc:0000022C2470BAC0) 1.73ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
FFT Done. Elapse time = 110499us
Gennady_F_Intel
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
