7302 Discussions
DESCINIT parameter number 9 had an illegal value
sfqian
I can execute the scalapack example of netlib. http://www.netlib.org/scalapack/examples/sample_pzheevx_call.f
However, when I use N = 600 instead of N = 4, some messages are printed:
{ 0, 0}: On entry to
DESC{ 0, 1}: On entry to
{ 1, 0}: On entry to
{ 1, 1}: On entry to
PSSYEVX parameter number 23 had an illegal value
I compile this example using intel mpi and intel mkl 2016 version.
mpiifort -O1 -o example1 sample_pssyevx_call.f -lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64 -lmkl_lapack95_lp64 -lmpi -lmkl_sequential -lmkl_intel_lp64 -lmkl_core -lpthread -lm -ldl
mecej4
You used a value of N (600) that is larger than the integer parameter MAXN (100) that is used in the example code to allocate some of the arrays. Did you remember to adjust MAXN accordingly?
mecej4
sfqian
Thank you so much! I changed the MAXN and the problem is solved.
