DPOTRI problems on AMD
may_ka
I ran a larger linear algebra workflow which also calls various blas and lapack function including potrf, trsm, potri, syrk, symm and gemm. The arrays involved can be up to 150,000 x 150,000.
I have observed that the workflow's processing time substantially increases when executed at an AMD cpu, up to the point that the workflow had to be interrupted. Investigating the issue I found that potri is the culprit, where MKL is not even returning. Observing the core usage while potri is called it is multi-core but substantially fluctuates between using all cores and only one.
Here is the setup:
  1. compiled with Intel Clang++ with arguments:
    1. -march=x86-64-v4
    2. -std=c++20
    3. -fPIE
    4. -std=gnu++20
    5. -ferror-limit=4 -O2
    6. -qopenmp
    7. -fp-model=precise
  2. all libraries are statically linked (including MKL, pthread and libiomp5)
System libraries are linked dynamically:
linux-vdso.so.1 (0x00000673cc8ff000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00000673cc807000)
libmvec.so.1 => /lib/x86_64-linux-gnu/libmvec.so.1 (0x00000673c0707000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00000673c06d9000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00000673c0400000)
/lib64/ld-linux-x86-64.so.2 (0x00000673cc901000)
software is executed on an Azure instance running Ubuntu 24.04 using environment variable settings
ulimit -s unlimited
export OMP_NUM_THREADS=48
export MKL_NUM_THREADS=48
export OMP_DYNAMIC=FALSE
export OMP_MAX_ACTIVE_LEVELS=2147483647
export OMP_PLACES=cores
export OMP_PROC_BIND=true
On a E96s v6 instance with an INTEL(R) XEON(R) PLATINUM 8573C processor the software behaves normally.
On a E96ads_v6 instance with an AMD EPYC™ 9004 processor the software hangs in the MKL potri routine.
Note that all other MKL routines (potrf, trsm etc) have not shown the above problems.
Any idea?
may_ka
The processing fro dpotri on a 1146878 x 1146878 matrix:
INTEL(R) XEON(R) PLATINUM 8573C, 48 cores3198 seconds
AMD EPYC™ 9004, 48 cores21141 seconds
This is an increase by factor 6.6.
The above numbers also apply for compiling using clang++ and linking against llvm omp.
The MKL version used is 2026.0.0.198.
ivanp
A quick calculations shows the size of this matrix is almost a 10 TB:
>>> 1146878**2 * 8 / 1024**3
9799.965820342302
According to this page, the Intel Xeon can address 4 TB of memory. And according to this sheet, the AMD EPYC could have up to 6 TB.
Could swapping to disk be the issue?
ivanp
I mistakenly linked the spec for the Intel® Xeon® Platinum 8570 Processor, not the 8573C.
But the Azure pages (links given below), show the following:
Size NamevCPUs (Qty.)Memory (GB)
Standard_E96ads_v696672
Standard_E96s_v696768
The machines differ in the local and remote storage they have available.
Sources:
- https://learn.microsoft.com/en-us/azure/virtual-machines/sizes/memory-optimized/esv6-series?tabs=sizebasic
- https://learn.microsoft.com/en-us/azure/virtual-machines/sizes/memory-optimized/eadsv6-series?tabs=sizebasic
may_ka
Hi @ivanp
the actual number is 146878. Sorry for the confusion.
I could solve the problem. A large range in diagonal elements with resulting borderline floating point numbers causes the issue. For some reason Intel handles the problem without overhead, contrarily to AMD.
ivanp
No worries. At 161 GB that should fit.
I have read elsewhere that denormalized numbers and gradual underflows can cause processing slowdowns.
