Different LU factorization result between libmkl_intel_ilp64.a and libmkl_intel_lp64.a
zhang__Shunkang
I am a novice in the field of Intel Math Kernel Library. However, when I tried to use the LU factorization function from LAPACK by compiling different libraries, I got different results as the following.
My C++ code is as simple as the following.
#include <mkl.h>
#include <iostream>
#include <ctime>    // For time()
#include <cstdlib>
int main()
    srand(time(0));
    double a[441];
    for (int i = 0; i < 441; i++)
        a = (double) rand() / RAND_MAX;
    int C = 21;
    lapack_int m1 = C;
    lapack_int n1 = C;
    lapack_int lda1 = C;
    lapack_int ipiv;
    lapack_int info1 = LAPACKE_dgetrf(LAPACK_COL_MAJOR, m1, n1, a, lda1, ipiv);
    std::cout << "Info1 is " << info1 << std::endl;
    info1 = LAPACKE_dgetri(LAPACK_COL_MAJOR, m1, a, lda1, ipiv);
    return 0;
I could get no error by linking library "libmkl_intel_lp64.a", but I got a "Segmentation fault (core dumped)" by linking library "libmkl_intel_ilp64.a". I have checked the intel official document which explains the difference between the two libraries.
There are mainly two difference mentioned in that document:
     1. Support large data arrays (with more than 231-1 elements)
     2.Enable compiling your Fortran code with the -i8 compiler option
I do not understand why I even got error by using libmkl_intel_ilp64.a. What's more, sometimes I also meet an error "tack smashing detected" by linking library "libmkl_intel_lp64.a" but "libmkl_intel_ilp64.a" is OK. Could you please help me figure it out? Thank you so much!
Ruqiu_C_Intel
Please add "-DMKL_ILP64" option to link library "libmkl_intel_ilp64.a" in your make file. It should fix your problem.
Ruqiu
Gennady_F_Intel
here is the output when linking with ILP64 API and compiled with  /DMKL_ILP64 option.
>_2.exe
MKL_VERBOSE Intel(R) MKL 2019.0 Update 4 Product build 20190411 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled processors, Win 2.60GHz cdecl intel_thread
MKL_VERBOSE DGETRF(21,21,00000052E531EDF0,21,00000052E531ED30,0) 1.36ms CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:2
Info is 0
MKL_VERBOSE DGETRI(21,00000052E531EDF0,21,00000052E531ED30,00000052E531ECB0,-1,0) 54.61us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:2
MKL_VERBOSE DGETRI(21,00000052E531EDF0,21,00000052E531ED30,000001CCD0FC8280,1344,0) 238.55us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:2
Info1 is 0
