Eigan Value Solution (LAPACKE_sggev)
Hamza_K_
 LAPACKE_sggev gives the Eigan Value in my code
The function is not giving correct answer when used on multiple nodes. When nodes = 1 it gives a correct answer
Also, if LAPACKE_sggev is not compatible with opem mpi which function should I use to calculate eigan value in my code.
If any more details are required kindly let me know.
Zhen_Z_Intel
Dear customer,
Could you please provide a test case that we will try to reproduce your problem. Thanks.
Fiona
Hamza_K_
Hamza_K_
Kindly run the Solution.cpp file
Solution configuration : Release
Platform : x86
Hamza_K_
I run the exe file through cmd witht he following command :
mpiexec -n 2 Solution.exe "C:\kgg.op4" "C:\mgg.op4"
Find the two op4 files attached in the zipped folder and copy them in C and give the following path
KIndly ask anything else, if required
Zhen_Z_Intel
Dear customer,
I tried to run your program, and get error message -13 which represents wrong input value of leading dimension of vl.
I find the reason, I tried to print massNoOfRow and massNoOfCol before calling ggev, they do not get a return value from ReadOP4Data function at the first time. If I set them equals to 1200, there would be no error for mkl eigen value calculation function. Could you please have a check if you meet the same problem. Thanks.
Fiona
Hamza_K_
It Worked!
Hamza_K_
Retval = 0 on nodes > 1 now
Hamza_K_
Working on a Project called DynaFlight the Eigen Value matrix is calculated using the function LAPACKE_sggev
Issue: Eigen Value Solution when separated from DynaFlight and executed on multiple threads doesn’t give the correct solution
The command used is
Hamza_K_
Complete Matrix values when executed through the cmd are in the excel file “Omega_cmd”
Correct Matrix when executed in DynaFlight is in “Output_Omega”
Hamza_K_
Output omega file
Hamza_K_
Waiting for your response. Thankyou
Zhen_Z_Intel
Dear customer,
Are you sure you are using same input for DynaFlight? I check with output_omega.txt, the length of return eigen vector is not equals to 1200, but 1080... I could only get result same as Omega_cmd.txt. I also checked with your data input file, both a & b are 1200*1200. I could not make sure the correctness of output_omega.txt.
Fiona
Zhen_Z_Intel
Another point is, in you program you write like this:
for (int i = 0; i < massNoOfRow; i++)
	for (int j = 0; j < massNoOfCol; j++)
		massData1D[i*massNoOfRow + j] = massData;
While the size of 1200*1200, there's no problem. But if the matrix is not square matrix, it is wrong... you should write as:
massData1D[i*massNoOfCol + j] = massData;
I do not understand why you are using multi-node. The function is not going to use multi-node. It's actually could only calculate in one node. If you set node equals to 2, you will probably find that massNoOfRow & col are 0 in node 1. That is why the calculation in first node you get error -13. You need to initial massNoOfRow & col equals to 1200 before calculation. The error of -13 could be removed. But this problem nwould not affect the result. The eigen value & vector should be correct.
Fiona
Hamza_K_
Hi. I'll check the results and see why they are not correct, thank you for input on that.
Responding to your second point where you said the function isn't going to use multi node.
Can the Lapacke_sggev function be used with multiple nodes or is it only for a single node. If it is for a single node only which routine should I use instead of it?
Zhen_Z_Intel
Dear customer,
I am afraid lapack functions are not for cluster. You could use Scalapack, but there's no function of generalized non-symmetric eigenvalue driver routine, only symmetric for Scalack.
Fiona
