Element-wise vector comparison
Mikhail_K_
I have a huge mxn matrix A where I need to compute A(i,j) > 0, ie. 1 for all values which are positive, and 0 otherwise
I would be better off writing it in C++, but let's assume I'm in a situation where I don't have admin rights and cannot install/compile anything. I'm using a single-threaded scripting language (VBA) to wrap calls to mkl_rt.dll, and any combination of MKL functions is still faster.
One way to solve this is to compute 1-0^(x+abs(x)), ie something like
    vdabs m*n, A(1, 1), temp(1, 1)
    vdadd m*n, A(1, 1), temp(1, 1), temp(1, 1)
    vdpow m*n, res(1, 1), temp(1, 1), res(1, 1)  /***** (res() is an array full of zeros)
    vdlinearfrac m*n, res(1, 1), res(1, 1), 0, -1, 0, 1, res(1, 1)
But the vdpow function is quite costly computation-wise (overall speed difference is ca x4 in favor of mkl, but I expect more from one single thread in VBA vs compiled multi-threaded code)
Another solution is to find the maximum value in the array, divide by max+1 to force all values into <-1, 1> and apply vdceil, <-1, 0] becomes 0, and <0, 1> becomes 1, but there can be some problems if the numbers are huge and end up as [-1, 1]
Can anyone think of a simpler way to do it?
Ying_H_Intel
Hi Mikhail,
It seems no simple function in MKL can do such operation
If possible, could you use other library like IPP library, which can do such operation by one function
for example
Conversion of a grayscale image to a bitonal image
IppStatus ippiGrayToBin_<srcDataType>1u_C1R  (please search IPP's developer guide)
ippiThreshold_GTVal  etc.
You mentioned you can't compile on one machine,  Could it possible for you to wrap IPP dll on other machine with admin right , then copy the dll to VBA, thus you can use IPP dll?
Ying
Ying_H_Intel
Hi Mikhail,
for example
Ying
Mikhail_K_
Yep, thanks, that's what I ended up doing.
Wasted whole evening trying to export some functions in ipps.h as stdcall to a custom dll...  But then realized stdcall is default in IPP... Is it?
In MKL its cdecl (though most functions have stdcall)?
MK
Mikhail_K_
By the way, why are multi-threaded vector arithmetic functions (like ippsMul_64f) depreciated in IPP, but its seemingly ok to have multi-threaded vdMul in MKL?
SergeyKostrov
Valued Contributor II
>>... >>...stdcall is default in IPP... Is it? Yes for Windows platforms. ( It is not clear what platform you're using / I think Windows... ) [ ippdefs.h ] ... #if defined( _WIN32 ) || defined ( _WIN64 ) #define __STDCALL __stdcall #define __CDECL __cdecl #define __INT64 __int64 #define __UINT64 unsigned __int64 #else #define __STDCALL #define __CDECL #define __INT64 long long #define __UINT64 unsigned long long #endif #if !defined( IPPAPI ) #if defined( IPP_W32DLL ) && (defined( _WIN32 ) || defined( _WIN64 )) #if defined( _MSC_VER ) || defined( __ICL ) #define IPPAPI( type,name,arg ) \ __declspec(dllimport) type __STDCALL name arg; #else #define IPPAPI( type,name,arg ) type __STDCALL name arg; #endif #else #define IPPAPI( type,name,arg ) type __STDCALL name arg; #endif #endif ...
Ying_H_Intel
Hi MK, Sergey,
Yes, IPP custom dll is using default stdcall.
Ying
