7303 Discussions
Entry Point Not Found for mkl_serv_print_verbose_info
reyes__randolph
I got this pop up error when I run my application:  The procedure Entry Point  mkl_serv_print_verbose_info could not be located in the dynamic link library.
I did add in my path the MKl folder where lib resides
Is there a specific Windows .NET Framework or Visual C++ Redistributable that I need to install?
Appreciate any help!
Randolph
Gennady_F_Intel
There is no specific Windows .NET Framework Redistributable that you need to install. I do believe the problem with your systems paths. Please check these paths once again.
You may also try to rebuild your application statically and see if the problem will go away. Please refer to the mkl linkder adviser to check how to link the application properly.
