7300 Discussions
Error While Loading Shared Libraries: libiomp5.so
CPati2
New Contributor III
Hi All,
I am running CentOS 7.3 on Intel Xeon Phi. I have successfully configured Parallel Studio XE 2017 update 5 with all the libraries and tools that come with it. However, for some reason I keep getting following error when I profile benchmarks like DeepBench, Intel LINKPACK or Intel Caffe with perf:
error while loading shared libraries: libiomp5.so: cannot open shared object file: No such file or directory
Both perf and benchmarks work standalone, only time they don't is when I hook them with each other. This wasn't the case before I had to re-install CentOS on my system. I have sourced MKL environment variables apart from other specific variables from /opt/intel/bin/*.sh. I haven't found this libiomp5.so installed anywhere on the system.
source /opt/intel/bin/compilervars.sh intel64
source /opt/intel/mkl/bin/mklvars.sh intel64
source /opt/intel/impi/2017.4.239/intel64/bin/mpivars.sh intel64
source /opt/intel/bin/iccvars.sh intel64
source /opt/intel/bin/ifortvars.sh intel64
Can anyone please share steps or suggestions on how to solve this issue?
CPati2
New Contributor III
Hi All,
I solved this by adding following in /etc/ld.so.conf:
/opt/intel/lib/intel64
and then run:
sudo ldconfig
Intel documentation lacks all these details.
CPati2
New Contributor III
Hi All,
and then run:
sudo ldconfig
Zhen_Z_Intel
Hi Chetan,
libiomp5.so is saved in compiler lib folder. Normally the path of Intel compiler lib will be added to LD_LIBRARY_PATH when you source /opt/intel/compilers_and_libraries_2017.x.xxx/linux/bin/compilervars.sh <ia32|intel64>
If you get this error message, please try to:
export LD_LIBRARY_PATH=/opt/intel/compilers_and_libraries_2017.x.xxx/linux/compiler/lib/intel64:$LD_LIBRARY_PATH
Fiona
Munasinghe__Indula
Hi
You can simply scp the libiomp5.so file from /opt/intel/lib/intel64 to coprocessor
scp libiomp5.so mic0:
Then copy this file to lib64 file in the coprocessor
cp libiomp5.so /lib64
Indula.
