7303 Discussions
Error: cannot find -lmkl_p4 ..... please help...........
debraj_de1
We were compiling a program with MKL.
The error shown is:
[ded@wci32-oib mm-app-0.0.2]$ make
cc -I/home/ded/intel/mkl/9.1.023/include -I/home/ded/mvapich-0.9.9/mvapich-0.9.9/include -L/home/ded/intel/mkl/9.1.023/lib/32 -lmkl_p4 -lvml -lguide -lpthread -lm
mm.c -o mm
/usr/bin/ld: skipping incompatible /home/ded/intel/mkl/9.1.023/lib/32/libmkl_p4.so when searching for -lmkl_p4
/usr/bin/ld: cannot find -lmkl_p4
collect2: ld returned 1 exit status
make: *** [mm] Error 1
The Makefile is as follows:
CC = /home/ded/mvapich-0.9.9/mvapich-0.9.9/bin/mpicc
MPI_INCLUDE = /home/ded/mvapich-0.9.9/mvapich-0.9.9/include
#MKL_DIR = /usr/local/mkl-7.0.17/mkl70
#MKL_DIR = /usr/local/mkl/mkl721
MKL_DIR = /home/ded/intel/mkl/9.1.023
MKL_PATH = $(MKL_DIR)/lib/32
MKL_INCLUDE = $(MKL_DIR)/include
all: mm
mm: mm.c
cc -I$(MKL_INCLUDE) -I$(MPI_INCLUDE) -L$(MKL_PATH) -lmkl_p4 -lguide -lpthread -lm
mm.c -o mm
clean:
rm -f mm
TimP
It looks as if your mpicc may be a 64-bit compiler, so you would have to switch to the corresponding library in the em64t section of your MKL library installation.
If your only reason for linking in Intel OpenMP support is on account of MKL, and you don't intend to ask for threading in MKL, the mkl serial library may be preferable.
