7303 Discussions
Error compiling custom DLL (builder) with pardiso
crispybits
Hello. The linker says:
mkl_core.lib(pardiso_parse_ooc_io_errors.obj) : error LNK2001: unresolved external symbol __fseeki64
The functions_list file contains one line:
pardiso
Make command line is:
nmake ia32 BUF_LIB=
It works fine with the default functions_list file.
Compiler is MS Visual C++ 2008 Express Edition
MKL version is 10.1.0.018
Computer is 32bit.
Gennady_F_Intel
I used to reporoduce your problem with MS Visual C++ 2008 Professioanl Edition
and all are OK.
1.
Please see below the output I got:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:AppsIntelMKL10.1toolsbuilder> nmake ia32 export=_pardiso_list.txt BUF_LIB=
Microsoft Program Maintenance Utility Version 9.00.21022.08
Copyright (C) Microsoft Corporation. All rights reserved.
set Lib=%Lib%;..\..\\ia32\lib\
if exist .temp_cdll rd /q /s .temp_cdll
Microsoft Library Manager Version 9.00.21022.08
link /DLL /MACHINE:IX86 /NODEFAULTLIB /def:user_def_file.def .temp_cdll*.obj ..\..\
\ia32\lib\mkl_intel_c.lib ..\..\\ia32\lib\mkl_intel_thread.lib ..\..\\ia32\lib\mkl_co
re.lib ..\..\\ia32\lib\mkl_solver.lib libiomp5md.lib msvcrt.lib kernel32.lib user32.lib /o
ut:"mkl_custom".dll
Microsoft Incremental Linker Version 9.00.21022.08
Creating library mkl_custom.lib and object mkl_custom.exp
2. The file called _pardiso_list.txt contains only one line: pardiso
3. MKL 10.1
crispybits
Cheers. Somehow it's fixed itself here too.
and all are OK.
1.
ut:"mkl_custom".dll
3. MKL 10.1
