7298 Discussions
Error during installation process of Intel oneAPI Math Kernel Library
Janell
I also need to integrate this with Visual Studio Code 2019, as stated in 1.Prerequisites/Step 3 here.
Attached is the detailed log file.
Thank you so much.
SofeaAzrin_A_Intel
Hi Janell,
Thank you for your question. We are trying to check the issue at our end.
SofeaAzrin_A_Intel
Can you try to re-install the onemkl/oneapi and check the box vs2019 while installing it. Then, can you check 'Tools - Options - Intel Compilers and Libraries - Intel Library for oneAPI' at VS2019 to confirm it. Let us know if you have any update on that.
