7301 Discussions
Error in Visual C++ program with Intel MKL BLAS routine.
satakarni_byngmail_c
Hi All
The following is the C++ program I am trying to compile in VC++ 2005.
I got the following error :
error LNK2019: unresolved external symbol _dasum referenced in function _main
The following is my code:
#include
#include "mkl.h"
using namespace std;
int main()
const int n = 100;
int INCR = 1;
double A;
int i;
double result;
for(i=0; i A = (double)i;
result = dasum(&n, A, &INCR);
cout << result;
return 0;
Can someone help me to resolve the problem ?
Satakarni
Todd_R_Intel
What libraries have you added to your link line? For a 32-bit system something like the following could be used:
mkl_intel_c.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib
Todd
Todd_R_Intel
Todd
Todd
Yeah I believe it is the problem of not linking to the libraries.
How to add libraries to the link line? (I have added MKL library path in VC++ directories.)
Can you please elobrate you explanation?
Appreciable for your valuable time.
SK
Gennady_F_Intel
Hi Satakarni,
Hi Below you can find short description for compiling and linking program with Intel MKL v.10.0 using the Microsoft* Visual Studio* 2008 or Microsoft* Visual Studio* 2005:
  1. Select View Solution Explorer (and make sure this window is active).
  2. Select Tools Options Projects and Solutions VC++ Directories.
  3. In the drop down menu titled Show directories for:, select Include Files, and then type in the directory for the Intel MKL include files (e.g. default: C:Program FilesIntelMKL10.0include).
  4. In the drop down menu titled Show directories for: select Library Files, and then type in the directory for the Intel MKL library files (e.g. default: C:Program FilesIntelMKL10.0ia32lib).
  5. In the drop down menu titled Show directories for: select Executable Files, and then type in the directory for the Intel MKL executable files (e.g. default: C:Program FilesIntelMKL10.0ia32bin).
  6. On the main toolbar select Project Properties Configuration Properties Linker Input and in the "Additional Dependencies" line, add the libraries you require
As Todd mentioned, for a 32-bit system something like the following could be used:
For more information about Linking application with Intel MKL version 10.0 you can find in userguide.pdf chapter 5 ).
--Gennady
