Error in mkl_sparse_z_set_value
Ahmadi__Afshin
I am struggling to change a single value of a matrix in internal Intel Sparse BLAS format using the mkl_sparse_z_set_value function. Most of the time  this function returns a value of 3. However, it does work some times! I have checked the status of memory allocation and also mkl_sparse_z_create_csr and there is no problem with them. Any idea why this issue is happening? Here is the code:
// Matrix size is Mat_Size x Mat_Size
// This matrix is going to be a diagonal matrix so the maximum number of non-zeros will be equal to Mat_Size
int Mat_Size = 10;
sparse_matrix_t  Ysh_CSR = NULL;
MKL_Complex16 *Ysh_val = NULL;
MKL_INT *Ysh_col = NULL;
MKL_INT *Ysh_row = NULL;
Ysh_val = (MKL_Complex16 *)mkl_malloc(Mat_Size * sizeof(MKL_Complex16), 64);
Ysh_col = (MKL_INT *)mkl_malloc(Mat_Size * sizeof(MKL_INT), 64);
Ysh_row = (MKL_INT *)mkl_malloc((Mat_Size + 1) * sizeof(MKL_INT), 64); // +1 is because we are using 3-aaray variation
mkl_sparse_z_create_csr(&Ysh_CSR, SPARSE_INDEX_BASE_ZERO, Mat_Size, Mat_Size, Ysh_row, Ysh_row + 1, Ysh_col, Ysh_val);
MKL_Complex16 temp;
temp.real = 2 ;
temp.imag = 3 ;
int info = mkl_sparse_z_set_value(Ysh_CSR, 1, 1, temp); // set the value of Ysh_CSR[1][1] to temp
printf("info is %i", info);
Ying_H_Intel
Hi Ahmadi,
Thank you for the post. We will investigate the problem and get back to you later. Could you pleas also submit the issue to https://supporttickets.intel.com/?lang=en-US​, where we can track the details, like compiler/mkl version , bug etc.
​Ying
Ahmadi__Afshin
Ying H. (Intel) wrote:
Hi Ahmadi,
​Ying
Dear Ying,
Were you able to investigate the problem?
Ying_H_Intel
Hi Ahmadi,
​Yes, we can reproduce the problem. So did you create a ticket  in https://supporttickets.intel.com/?lang=en-US ? please let me know the ticket number.
​Ying
Ahmadi__Afshin
Hi Ahmadi,
​Ying
Hi Ying,
The ticket number is 03319553. How long do you think it is going to take to fix the issue?
Best,
Afshin
Ying_H_Intel
Hi  Afshin,
Please refer to the reply from the 03319553. It seems you are creating a csr handle, but with invalid matrix value. If there are exact value for the Ysh_row, , Ysh_col, Ysh_val, then your code will work.
SPARSE_STATUS_INVALID_VALUE = 3, /* invalid input value */
Best Regards
Ying
Ahmadi__Afshin
Hi  Afshin,
Best Regards
Ying
Hi Yin,
My code is actually fine and there is not problem with creating the CSR handle. Ysh_$ are just empty arrays with the right memory size to keep the future sparse matrix information. However, what is wrong is that the mkl_sparse_z_set_value function can only be used after the CSR handle has been filled with values (e.g., after converting the dense matrix to sparse and storing the results in the CSR handle). I believe the language of MKL manual is vague in explaining this function. I also think Intel should include a similar function to retrieve an element from the sparse function. For example, if you add two sparse matrices together and you want to read diagonal elements of the resulting function, there is no function for that.
Anyway, I really appreciate your help in this matter.
Best,
Afshin
MariaZh
Hello Afshin,
You're right, mkl_sparse_?_create_csr is supposed to be used only if one allocated and initialized all rows_start(_end)/col_indx and values arrays. On the basis of this information CSR handle will be created and can be used with all IE SpBLAS functionality.
mkl_sparse_?_set_value routine can only change one of the existing values from matrix to another (please, refer to
https://software.intel.com/en-us/mkl-developer-reference-c-mkl-sparse-set-value). That explains why there was an error related to invalid input when passing non-initialized arrays to mkl_sparse_?_create_csr and then to mkl_sparse_?_set_value routines.
In order to retrieve an element from the resulting matrix you can use mkl_sparse_?_export_csr, however it's currently not supported to export only the part of the matrix from CSR Handle.
Hope this was helpful!
Maria
