Error in the documentation of feast
marc_d_
I would like to report an error in the documentation of the reference manual for the extended eigensolver (feast). In the rci interface description, the parameter ijob is detailed. When ijob = 30 or 40, it is written that i is fpm(25) and j fpm(24)+fpm(25)-1 whereas i is equal to fpm(24). With this value of i, the solver works correctly.
Best regards.
Gennady_F_Intel
thanks for the report -- we will check the documentation
Gennady_F_Intel
Yes, this is doc problem. Your suggestion is correct. We will fix it into the one of the next updates. Thanks for the issue.
