Error installing intel MKL
ilkka_n_
I have a problem with installing the mkl 11.3 on Ubuntu 15.04. The installation stops at 32% and gives the following error message:
MKL_RT_X64 ERROR: Unable to extract data from RPM package. Please check that temporary directory is not full.
I've run it as root.
Gennady_F_Intel
thanks for the report. I am not exactly aware if this is the real problem for MKL because of the 15 version is not officially supported. Please have a look at the System Requirements for 11.3
Supported operating systems
  • Debian* 7 (IA-32 / Intel® 64)
  • Ubuntu* 12.04 (Intel® 64)
  • Ubuntu* 13.10 (IA-32 / Intel® 64)
  • Ubuntu* 14.04 LTS (IA-32/Intel® 64)
nevertheless, we will ask to see at the problem one of our Install guru.
Evgeniy_K_Intel
Hello!
Thank you for your report. Could you please check actual free space in /tmp? For successful installation it needs about 300M at least. Is it possible that some other applications use temporary directory intensively during the installation?
Best regards, Evgeny
ilkka_n_
There should be enough room in the /tmp folder.
It's a fresh installation of ubuntu 15.04 with RAID 0 configuration.
No other application is using the /tmp intensively.
Evgeniy_K_Intel
Could you please check md5 sum of the archive l_mkl_11.3.0.109.tgz and the file rpm/intel-mkl-109-11.3.0-109.x86_64.rpm?
It should be:
l_mkl_11.3.0.109.tgz 47567e38801efe273b36b5250c759af7
intel-mkl-109-11.3.0-109.x86_64.rpm 6ece1fc38dcc2b934a589b07b0b92486
