7303 Discussions
Error loading MKL Environment Modules file in Intel(R) oneAPI for Linux version 2023.2.0
Ron_Green
Symptom:
Linux users who utilize the LMOD or Sourceforge Environment Module utility ( module load ) to set their environment variables may see the following error in the 2023.2.0 release:
module load /opt/itnel/oneapi/modulefiles/mkl/latest
Loading mkl/2023.2.0
ERROR: Unable to locate a modulefile for 'compiler-rt'
ERROR: Load of requirement 'compiler-rt' failed
If you are not a Linux user, OR if you use 'setvars.sh' or 'vars.sh' to set environment, this error does not apply to you and will not impact your work.
A description of the problem and workarounds is described in this Missing Modulefiles article .
