FFT parallelization comparison
Marshall__Michael_B
Has any done any comparison of the different parallelization techniques for the 1 D FFTs?
I'd like to know which method in general is faster? internal threading or user threading?
Currently my application is single-threaded but improving the FFT time would warrant the added complexity of handling our own threads for this app.
Gennady_F_Intel
First of all, please look at the list of threaded functions into the version of MKL which you are using.You can find this list into MKL User's Guide ( see chapter 6 - "Using Intel MKL Parallelism").
There are some restrictions for this functionality, e.g for the latest MKL 10.2 Update 4 :
1D real-to-complex and complex-to-real transforms are not threaded.
1D complex-to-complex transforms using split-complex layout are not threaded.
Prime-size complex-to-complex 1D transforms are not threaded.
and etc..
--Gennady
Marshall__Michael_B
I am using MKL 10.2.3; my specific use case is a 1 Dimensional complex to complex transform.
At the beginning of Chapter 6, the user guide says "FFT" is threaded. It does not mention any of the restrictions listed in your reply.
In previous versions the memory array given to the FFT needed to be a factor of 128 for best performance. Is this still the case?
Does running the transform using out-of-place versus in-place memory make a difference?
barragan_villanueva_
Valued Contributor I
You know, Gennady added that fragment with limitations from MKL 10.2.4 User's Gude.
As to memory alignments: 16, or 128 or even page-alignment should provide better performance because using vectorizing code in DFT-kernels and compact page migrations (I mean DTLB misses).
About comparison out-of-place versus in-place 1D
for small sizes the difference isnonsignificant (see below Gfs for 1thread):
Forward_DFT_C,     x210,    8.432,1th,1D,in-place
Forward_DFT_C,     x210,    8.502,1th,1D,out-of-place
Forward_DFT_C,     x504,    9.896,1th,1D,in-place
Forward_DFT_C,     x504,    9.885,1th,1D,out-of-place
but for large sizes (more that cache size) it will be significant difference
Forward_DFT_C,     x3211264,    4.196,1th,1D,in-place
Forward_DFT_C,     x3211264,    4.312,1th,1D,out-of-place
Forward_DFT_C,     x6250000,    3.763,1th,1D,in-place
Forward_DFT_C,     x6250000,    3.837,1th,1D,out-of-place
