FGMRES problem with IPAR(19)
ljbetche
I am having an oddproblem with the FGMRES sparse solver. My first two calls to DFGMRES successfully return valuesRCI_Request = 1 and RCI_Request = 3, however, after the appropriate actions have been taken and control is returned to DFGMRES, I receive the following error in MKL_RCI_FGMRES_Log.txt:
MKL RCI FGMRES ERROR:
Parameter IPAR(19)=0 must be a positive integer. Probably,
parameter IPAR(19) was altered by mistake outside of DFGMRES routine. The solution
may be wrong...
Note that IPAR(19) = 0 immediately after calling DFGMRES_INIT, so it seems that it should have this value still during the first iteration (IPAR(19) is a service variable denoting the location of certain information in the TMP work array). I can't think of any reason for this problem, so any help would be greatly appreciated. Thanks.
Lee
ljbetche
Just to be clear, I do not manually modify IPAR(19) at any point. If it is helpful, the relevant portion of my code (strict F77, with the exception that some arrays are allocatable, as was suggested in my other thread of a few days ago) is given below:
CALL DFGMRES_INIT(NEQ,XN,BN, RCIREQ,IPAR,DPAR,TMP)
IF(RCIREQ.NE.0) THEN
WRITE(ITERMO,5000)
GOTO 9999
ENDIF
IPAR(1) = NEQ
IPAR(2) = 1
IPAR(3) = 1
IPAR(4) = 0
IPAR(5) = MAXITS
IPAR(6) = 1
IPAR(7) = 1
IPAR(8) = 1
IPAR(9) = 1
IPAR(10) = 0
IPAR(11) = 1
IPAR(12) = 1
IPAR(13) = 0
IPAR(14) = 0
IPAR(15) = RSTITS
IPAR(31) = 1
DPAR(1) = RTOL
DPAR(2) = ATOL
DPAR(3) = 0.0
DPAR(4) = 0.0
DPAR(5) = 0.0
DPAR(6) = 0.0
DPAR(7) = 0.0
DPAR(8) = ZTOL
DPAR(31) = 10.0**(-20)
DPAR(32) = 10.0**(-12)
* Preconditioner
CALL NULLV(BILU0, 1,NENT,NENT)
CALL DCSRILU0(NEQ,AN,IA,JA, BILU0,IPAR,DPAR,IERR)
IF(IERR.NE.0) THEN
WRITE(ITERMO,5000)
GOTO 9999
ENDIF
* Solver
1000 CONTINUE
CALL DFGMRES(NEQ,XN,BN, RCIREQ,IPAR,DPAR,TMP)
* Proceed according to Reverse Communication Interface
* request from solver given in RCIREQ
IF(RCIREQ.EQ.0) THEN
* Solution obtained
GOTO 2000
ELSEIF(RCIREQ.EQ.1) THEN
* Multiply coefficient matrix by work vector and
* return to solver
COUNT = IPAR(22)
DO 1100 I=1,NEQ
WORK1(I) = TMP(COUNT)
COUNT = COUNT+1
1100 CONTINUE
CALL MKL_DCSRGEMV('N',NEQ,AN,IA,JA,WORK1, WORK2)
COUNT = IPAR(23)
DO 1105 I=1,NEQ
TMP(COUNT) = WORK2(I)
COUNT = COUNT+1
1105 CONTINUE
GOTO 1000
ELSEIF(RCIREQ.EQ.3) THEN
* Apply preconditioner and return to solver
COUNT = IPAR(22)
DO 1300 I=1,NEQ
COUNT = COUNT+1
1300 CONTINUE
CALL MKL_DCSRTRSV('L','N','U',NEQ,BILU0,IA,JA,
C WORK1, TRVEC)
CALL MKL_DCSRTRSV('U','N','N',NEQ,BILU0,IA,JA,
C TRVEC, WORK2)
COUNT = IPAR(23)
DO 1305 I=1,NEQ
COUNT = COUNT+1
1305 CONTINUE
GOTO 1000
ELSE
* Failure of solution procedure
WRITE(ITERMO,5000)
GOTO 9999
ENDIF
* Obtain solution and assign
2000 CONTINUE
CALL DFGMRES_GET(NEQ, XN,BN,RCIREQ,IPAR,DPAR,TMP,ICOUNT)
WRITE(ITERMO,5000)
GOTO 9999
ENDIF
ROW = 1
DO 2010 I=IB,IE
DO 2005 J=1,N
SOL(N*(I-IB)+J) = XN(ROW)
ROW = ROW+1
2005 CONTINUE
2010 CONTINUE
Lee
Alexander_K_Intel2
Quoting - ljbetche
WRITE(ITERMO,5000)
GOTO 9999
ENDIF
IPAR(1) = NEQ
IPAR(2) = 1
IPAR(3) = 1
IPAR(4) = 0
IPAR(5) = MAXITS
IPAR(6) = 1
IPAR(7) = 1
IPAR(8) = 1
IPAR(9) = 1
IPAR(10) = 0
IPAR(11) = 1
IPAR(12) = 1
IPAR(13) = 0
IPAR(14) = 0
IPAR(15) = RSTITS
IPAR(31) = 1
DPAR(1) = RTOL
DPAR(2) = ATOL
DPAR(3) = 0.0
DPAR(4) = 0.0
DPAR(5) = 0.0
DPAR(6) = 0.0
DPAR(7) = 0.0
DPAR(8) = ZTOL
* Preconditioner
IF(IERR.NE.0) THEN
WRITE(ITERMO,5000)
GOTO 9999
ENDIF
* Solver
1000 CONTINUE
* Solution obtained
GOTO 2000
* return to solver
COUNT = IPAR(22)
DO 1100 I=1,NEQ
COUNT = COUNT+1
1100 CONTINUE
COUNT = IPAR(23)
DO 1105 I=1,NEQ
COUNT = COUNT+1
1105 CONTINUE
GOTO 1000
COUNT = IPAR(22)
DO 1300 I=1,NEQ
COUNT = COUNT+1
1300 CONTINUE
C WORK1, TRVEC)
C TRVEC, WORK2)
COUNT = IPAR(23)
DO 1305 I=1,NEQ
COUNT = COUNT+1
1305 CONTINUE
GOTO 1000
ELSE
WRITE(ITERMO,5000)
GOTO 9999
ENDIF
2000 CONTINUE
WRITE(ITERMO,5000)
GOTO 9999
ENDIF
ROW = 1
DO 2010 I=IB,IE
DO 2005 J=1,N
ROW = ROW+1
2005 CONTINUE
2010 CONTINUE
Lee
Hi Lee,
To correctness you need tocall DFGMRES_CHECKbetween init of preconditioner (DCSRILU0) and main part of DFGMRES.
With best regards,
Alexander
ljbetche
Alexander,
I can't believe I forgot to do the check! Thank you so much. I'll try that now.
Lee
Alexander_K_Intel2
Quoting - ljbetche
Alexander,
Lee
Lee,
You are welcome :)
Alexander
