7302 Discussions
Facing The Problem To Linking With Static Library
Ramagounder_t_
I am facing the problem to linking with static library.
I am getting the below error message.
exchange_data.c:(.text+0x374): undefined reference to `ompi_mpi_byte'
exchange_data.c:(.text+0x3e2): undefined reference to `ompi_mpi_byte'
exchange_data.c:(.text+0x4d3): undefined reference to `ompi_mpi_int'
exchange_data.c:(.text+0x5b7): undefined reference to `ompi_mpi_byte'
exchange_data.c:(.text+0x673): undefined reference to `ompi_mpi_comm_world'
exchange_data.c:(.text+0x680): undefined reference to `ompi_mpi_byte'
exchange_data.c:(.text+0x6cc): undefined reference to `ompi_mpi_byte'
exchange_data.c:(.text+0x718): undefined reference to `ompi_mpi_byte'
exchange_data.c:(.text+0x843): undefined reference to `ompi_mpi_int'
exchange_data.c:(.text+0xa62): undefined reference to `ompi_mpi_byte'
exchange_data.c:(.text+0xb54): undefined reference to `ompi_mpi_int'
exchange_data.c:(.text+0xb7c): undefined reference to `ompi_mpi_int
Above undefined symbol is matches with following STATIC library.
/app/intel/composer_xe_2013.1.117/mkl/lib/intel64/libmkl_blacs_openmpi_ilp64.a.
So, In the Make file I've add the flags in the following way.
LIBS      = -L$(HYPRE_DIR)/lib -lHYPRE  -L/app/intel/composer_xe_2013.1.117/mkl/lib/intel64/
LFLAGS    = $(LINKOPTS) $(LIBS) -lstdc++  -lmkl_blacs_openmpi_ilp6
After that also while make. I get the same error message.
Could you help me to resolve the problem to link with static library?
Thanks & Regards,
Vijay Kumar TP
TimP
Using MKL link advisor: http://software.intel.com/sites/products/mkl/MKL_Link_Line_Advisor.html
you would expect to see a requirement to quote the full path for each required static library, and to use the start-group ... end-group directives for the group of 3 basic Intel MPI libraries including mkl_ilp64.
If you have continued difficulty after reading the docs, the MKL forum would be the place to ask.
Needless to say, in case you don't wish to deal with the complexity of static linking, there is a default of dynamic linking, and dynamic linking would be a useful first step to assure that you have specified the necessary libraries.
Ramagounder_t_
Thanks for your update Tim.
That symbol matches only with STATIC library that symbol does not matches with any DYNAMIC library.
Thanks & Regards,
Vijay Kumar TP
Ying_H_Intel
Hi Vijay,
Have you installed OpenMPI in your compile environment? The symbols of ompi_mpi_int are used in the libmkl_blacs_opempi_lp64 or ilp64.a. but not defined in MKL library.  They should be from OpenMPI.  So you may need to build your application with OpenMPI CC or link OpenMPI library manually.
 If you also need MKL library, then as Tim mentioned, you need to add the MKL libraries group in your link line.
for example, I build a small program recently with the Intel MPI. The command line as below.
/opt/intel/impi/4.1.0/intel64/bin/mpiicc -o test.out myTest.c -I/opt/intel/composer_xe_2013.3.163/mkl/include
/opt/intel/composer_xe_2013.3.163/mkl/lib/intel64/libmkl_scalapack_lp64.a -Wl,--start-group  /opt/intel/composer_xe_2013.3.163/mkl/lib/intel64/libmkl_intel_lp64.a /opt/intel/composer_xe_2013.3.163/mkl/lib/intel64/libmkl_intel_thread.a /opt/intel/composer_xe_2013.3.163/mkl/lib/intel64/libmkl_core.a /opt/intel/composer_xe_2013.3.163/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.a -Wl,--end-group -lpthread -lm -openmp
Ying
$ nm  libmkl_blacs_openmpi_lp64.a |grep ompi_mpi_byte
                 U ompi_mpi_byte
$nm  libmkl_blacs_openmpi_ilp64.a |grep ompi_mpi_byte
                 U ompi_mpi_byte
TimP
As Ying mentioned, you would specify the ompi library only when you are building and running with OpenMPI.  It won't work with other MPI implementations.
Ramagounder_t_
CASE 1
Make file parameter.
CC        = mpicc
F77       = mpif77
CXX       = mpic++
F90       = mpif90
HYPRE_DIR = /app/hypre280 (Compile with GCC LIBRARY)
compiled successfully only with openmpi compiler.
CASE 2
In that same case if I replace
CC        = mpicc
F77       = mpif77
CXX       = mpic++
F90       = mpif90
HYPRE_DIR = /app/hypre-2.9.0b/ (Compile with INTEL LIBRARY)
compiled successfully only with INTEL  compiler.
When I try to cross compile with (HYPRE - compile gcc ) and intelmpi  in that case only I am getting error message Still now that problem is not yet resolved.These analysis I am doing for Application tuning for better performance.
What you've shared message it is really helpful.
Thanks for your support TIM & YING
Thanks & Regards,
Vijay Kumar TP
TimP
With Intel MPI, unless you over-rule the way it installs, mpif77 and mpif90 are wrappers for gfortran, which will be incompatible with ifort.  The mkl_blacs libraries come in versions for several different MPIs.  You must not mix libraries for different MPI or between gfortran and ifort.
Rathod__Tejal
Hello Everyone,
                     I am facing same error. I tried all the above solution but still got this error .
main.o: In function `main':
/home/ipr/source-gravity/main.c:62: undefined reference to `ompi_mpi_comm_world'
/home/ipr/source-gravity/main.c:63: undefined reference to `ompi_mpi_comm_world'
/home/ipr/source-gravity/main.c:134: undefined reference to `ompi_mpi_comm_world'
/home/ipr/source-gravity/main.c:135: undefined reference to `ompi_mpi_comm_world'
/home/ipr/source-gravity/main.c:135: undefined reference to `ompi_mpi_op_sum'
/home/ipr/source-gravity/main.c:135: undefined reference to `ompi_mpi_double'
/home/ipr/source-gravity/main.c:136: undefined reference to `ompi_mpi_comm_world'
/home/ipr/source-gravity/main.c:136: undefined reference to `ompi_mpi_op_sum'
/home/ipr/source-gravity/main.c:136: undefined reference to `ompi_mpi_double'
/home/ipr/source-gravity/main.c:137: undefined reference to `ompi_mpi_comm_world'
/home/ipr/source-gravity/main.c:137: undefined reference to `ompi_mpi_op_sum'
/home/ipr/source-gravity/main.c:137: undefined reference to `ompi_mpi_double'
/home/ipr/source-gravity/main.c:138: undefined reference to `ompi_mpi_comm_world'
/home/ipr/source-gravity/main.c:138: undefined reference to `ompi_mpi_op_sum'
/home/ipr/source-gravity/main.c:138: undefined reference to `ompi_mpi_double'
/home/ipr/source-gravity/main.c:139: undefined reference to `ompi_mpi_comm_world'
/home/ipr/source-gravity/main.c:139: undefined reference to `ompi_mpi_op_sum'
/home/ipr/source-gravity/main.c:139: undefined reference to `ompi_mpi_double'
/home/ipr/source-gravity/main.c:176: undefined reference to `ompi_mpi_comm_world'
/home/ipr/source-gravity/main.c:176: undefined reference to `ompi_mpi_dblprec'
/home/ipr/source-gravity/main.c:177: undefined reference to `ompi_mpi_comm_world'
/home/ipr/source-gravity/main.c:177: undefined reference to `ompi_mpi_dblprec'
Makefile:21: recipe for target 'main' failed
make: *** [main] Error 1
CC    = mpiicc -O3 -g -Wall
INCLUDE = -I/opt/intel/parallel_studio_xe_2018/compilers_and_libraries_2018/linux/mpi/intel64/include -I/home/ipr/softwares/include
LIBS     = -L/home/ipr/softwares/lib -L/opt/intel/parallel_studio_xe_2018/compilers_and_libraries_2018/linux/mpi/intel64/lib
LFLAG    = -lm -lgsl -lgslcblas
Could you help me to resolve the problem?
Thanks & Regards,
Tejal Rathod.
