Failure during collective
Sanjiv_T_
Hi ,
I have compiled espresso with intel mpi and MKL library but getting error Failure during collective error when ever it is working fine with openmpi.
is there problem with intel mpi
Fatal error in PMPI_Bcast: Other MPI error, error stack:
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x516f460, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
MPIR_Bcast_impl(1670)...:
I_MPIR_Bcast_intra(1887): Failure during collective
MPIR_Bcast_intra(1524)..: Failure during collective
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x5300310, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x6b295c0, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x67183d0, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x4f794c0, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
[0:n125] unexpected disconnect completion event from [22:n122]
Assertion failed in file ../../dapl_conn_rc.c at line 1128: 0
internal ABORT - process 0
PMPI_Bcast(2112)........: MPI_Bcast(buf=0x56bfe30, count=96, MPI_DOUBLE_PRECISION, root=4, comm=0x84000004) failed
/var/spool/PBS/mom_priv/epilogue: line 30: kill: (5089) - No such process
Kindly help us for resolving this
sanjiv
Ying_H_Intel
Hi Sanjiv,
Could you please provide us a small test case?
And If needed, you may post the issue to Intel Cluster Forum  https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology, where Intel MPI experts may help directly.
Ying
Sanjiv_T_
Hi Ying,
Please find the attached espresso input file and pseudopotential.
Kindly help us for thins issue..
Sanjiv
James_T_Intel
Sanjiv,
What versions of Quantum Espresso, Intel® MPI Library, and Intel® Math Kernel Library are you using?  I will attempt to reproduce this locally.
James.
