7303 Discussions
Finding different versions of MKL when using CMake on Windows
AndrewC
New Contributor III
After installing MKL, CMake files are installed in
C:\Program Files (x86)\Intel\oneAPI\mkl\latest\lib\cmake\mkl\
Also as part of the installation process some change is made so CMake will always  look in the above location "first".
Does anyone know where this is recorded? The Windows registry? Somewhere in the CMake installation?
I need to be able to change where CMake finds MKL ( to use older/different versions) and this behavior seems impossible to ovveride.
Gennady_F_Intel
You can use MKL_ROOT cmake variable to specify the oneMKL libs and headers location.
e.g. build for oneMKL examples from C:/Users/user/local_onemkl,
cmake .. -DTARGET_FUNCTIONS="blas/cblas_dgemmx"
-- Found C:/Users/user/local_onemkl/lib/mkl_core_dll.lib
-- Found DLL: C:/Users/user/local_onemkl/bin/mkl_core.2.dll
And you can change the location with MKL_ROOT
cmake .. -DMKL_ROOT="C:\Program Files (x86)\Intel\oneAPI\mkl\2024.0" -DTARGET_FUNCTIONS="blas/cblas_dgemmx"
-- Found C:/Program Files (x86)/Intel/oneAPI/mkl/2024.0/lib/mkl_core_dll.lib
-- Found DLL: C:/Program Files (x86)/Intel/oneAPI/mkl/2024.0/bin/mkl_core.2.dll
Please note, MKLConfig.cmake could be not always compatible with the older oneMKL packages because of library versions, missed dependencies or package structure.
AndrewC
New Contributor III
HI Gennady,
I just worked this out. The intel setvars.bat sets the variable CMAKE_PREFIX_PATH which is used to find MKL/IPP etc.
Andrew
