First step to MKL
smtp12357
Hi
I'm jast now installed Intel C++ Compiler on linux machine and have problems with mkl.
1. I wrote simple code and tried to compile it with the line command
/opt/intel/Compiler/11.0/081/bin/ia32/icc first.c -lmkl_lapack -o first
but I got catastrophic error: could not open source file "mkl.h" (I used #include "mkl.h").
What is wrong?
2. The second question is not urgent for me, but it's interesting too. One gay said me that parallel
computations with mkl works on 64bit linux machine only, but I use 32bit one now. Is it true?
If not, could anybody show me a line commad for parallel start for Core 2 Duo.
TimP
1. You didn't specify the -I path to your MKL include directory in your compile command, such as -I/opt/intel/Compiler/11.0/081/mkl/include/
2. assuming that aspersion is a typo, there is a complete MKL installation in your 32-bit 11.0 compiler installation, saving you some of the headaches about choosing the 32-bit support in past versions of MKL. There are a few differences in the names of the libraries required; there is no support for 64-bit integers, since those aren't efficient in 32-bit mode. Please look at the docs for example compile commands.
Gennady_F_Intel
The first question:
If you use intel compiler.plese try to use the following lbraries:
libmkl_intel.a libmkl_intel_thread.a libmkl_core.a libiomp5.so
The second question:
thats not correct. MKL performs parallel computations on IA32, Intel64 and IA64 platforms.
<> You have to link threaded libraries and by default thats all you have to do.
You application will be running on all treads available on your system.
More info about treading in MKL and how you can manage you can find in userquide manual ( see ../doc folder )
--GIF
smtp12357
Thanks tim18, thanks Gennady Fedorov
I have tried to take into account yours answers and start compilation with the following command line:
/opt/intel/Compiler/11.0/081/bin/ia32/icpc first.cpp -I/opt/intel/Compiler/11.0/081/mkl/include/
-L/opt/intel/Compiler/11.0/081/mkl/lib/32 -lmkl_intel -lmkl_core -lmkl_intel_thread -liomp5 -o first
but I got the following error:
/opt/intel/Compiler/11.0/081/lib/ia32/libiomp5.so: undefined reference to 'pthread_atfork'
if I use command without "-L..." i.e.
I have error:
Id: cannot find -lmkl_intel
Does anybody know what is wrong?
Gennady_F_Intel
please add "-lpthread -lm" in the end of the linking line
smtp12357
Fine, it works
Thank you very much!
Good forum
